Deploying Maya with munki
We are currently using Casper to deploy Maya in our environment and it works well.  However we are currently evaluating an alternative deployment solution called munki and need to address deploying Maya with this new tool.  I am posting here because so far the solutions I have found envolve extracting packages and installing them in a certain order.  Quite frankly it's a bit messy.  Does Autodesk offer any recommendations/support for deployment through munki?
Replies (8)
BJ.C
Hello @Anonymous
Does Autodesk offer any recommendations/support for deployment through munki ? Official support - NO  I can find only a couple of old cases of anyone deploying Autodesk products using Munki so we would have very little to recommend. That does not mean that it would not work or if you had an existing case with Autodesk that they would not attempt to help you.
If you are successful I would suggest posting your results and methodology in this post. Your experience could become valuable to other using Munki with Autodesk products!
Thank you for taking part in our community forum!
Kind Regards,
BJ.C
Technical Support Specialist
I was actually successful at installing Maya 2016 using munki as a
deployment method. The process that I used was a follows:
1. Take the "Install Maya 2016.app" package and nest inside a package that
copies it to the /tmp folder. Import the resulting package into munki.
2. Add an install script to the package in Maya using Autodesk's command
line arguments. The one I used was this:
#!/bin/bash
cd /tmp/Install\ Maya\ 2016.app/Contents/MacOS
sudo ./setup --noui --force --serial_number=XXX-XXXXXXXX
--product_key=793H1 --license_type=kStandalone
sudo rm -rf /tmp/Install\ Maya\ 2016.app/
Adjust the serial number, product key and other arguments accordingly more
info on what the arguments do can be found here:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/CloudHelp/cloudhelp/2016/ENU/Instal...
I also added a line at the end to remove the temporary directory.
That's it! Works great. Some of this information can be found on munki
forums, but most scripts that I found were way too cluttered also this
solution was in most cases buried in blog posts way below more complicated
methods for installing Maya.
Cheers!
avto
Autodesk Support
Autodesk Support
Hi Dwarren,
Thank you for updating this thread and providing your workflow to the community. Thank you.
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
Thanks, glad I could help.
One correction:  Step number 2 shoudl say "Add an install script to the package in MUNKI.." not Maya
Just an update.  I was new to munki at the time.  I did not realize that you can change the install location so nesting the installer within an installer is not necessary, you just need to install to the /tmp folder and proceed with the same script.
Cheers!
natasha.l
Hello @Anonymous,
Thank you for the updates and contributing to the community. Smiley Happy
Update for 2017 Standalone install.  A few lines need to be added to the end of the script.
#!/bin/sh
#Note: the installer has been copied to the /tmp/ folder
cd /tmp/Install\ Maya\ 2017.app/Contents/MacOS
sudo ./setup --noui --log=/var/log/autodesk/2017/INSTALL.log --force --serial_number=XXX-XXXXXXXX --product_key=657I1 --license_type=kStandalone
# Using adlmreg to activate the license
cd /tmp/Install\ Maya\ 2017.app/Contents/Resources
#Note:  for this is for standalone, for Network install you will need to change the product key and use an "N" instead of an "S".
sudo ./adlmreg -i S 657I1 657I1 2017.0.0.F XXX-XXXXXXXX /Library/Application\ Support/Autodesk/Adlm/PIT/2017/MayaConfig.pit
sudo mkdir /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F
sudo touch /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LGS.data
sudo chmod 777 /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LGS.data
#Note:  For a network install change this to echo "_NETWORK"
echo "_STANDALONE" >> /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LGS.data
#For Network install remove the comment (#) markers from the following commands:
#echo "_NETWORK" >> /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LGS.data
#echo "SERVER servername 000000000000" >> /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LICPATH.lic
#echo "USE_SERVER" >> /Library/Application\ Support/Autodesk/CLM/LGS/657I1_2017.0.0.F/LICPATH.lic
Cheers!
natasha.l
Hello @Anonymous,
Thank you for being a part of the community and providing this helpful information. Visitors of the board will greatly appreciate! Smiley Happy
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
