Announcements
could not obtain lisence error 43
downloaded maya 2016 student version and it keeps giving me error after installation could not obtain lisence error 43
i perviously tried the trial version of it but now not able to get it working
tried to uninstall and re install tried clean uninstall registrey and all that stuff nothing i found i working
help me please
there is a picture of the error attached here
BJ.C
Hi
I'm sorry to hear that you've been having problems with your installation.  Let's remove the Autodesk Trusted Storage file. This is a licensing file and looks like this:
ADSKFLEX_NUMBERS_TSF.data
It should be located here:  C:\ProgramData\FLEXnet   Delete this file.  Restart the program and a new one should be created for you.
Give this a try and do not hesitate to reply to this post if you have a problem.
Thanks for taking part in our community forum!
BJ.C
Technical Support Specialist
The file you mentioned is not found in my ProgramData ?! i didn't mention im using windows 10 btw
BJ.C
Hi hijjawi.
Unfortunately, Windows 10 is not yet an officially supported operating system across the Autodesk product line.  However, some users have found the instructions for a workaround at this post to be a successful solution to installing Autodesk products on a Windows 10 system.
http://forums.autodesk.com/t5/autocad-architecture-general/this-is-how-to-install-autocad-2015-to-wi...
Please proceed with caution.  Product Support will provide their best effort to assist customers who have issues with current Autodesk products running on Windows 10.
Please post back and tell me how you made out if you attempt the workaround.
BJ.C
