Installation & Licensing
Accepted Solution
Connection error
31 Views, 4 Replies
03-20-2017 04:18 AM
Hi, I'm installing 3ds max on my Mac using Windows7/Parallels but, during the first run of the, in the "Let's Get Started" window I can't enter my serial number (I got a teacher license) 'cause no new window appears. If I try to sign in, the "Connection Error" window appears and I can not do anything (the "Try again" button brings me to the "Connection error" window).
Please, help me!
Hi, thanks for your answer!
Without making any setting change, now 3ds max works!
I tried to start the program as an administrator, and this time it worked!
Thanks again for the time you spent to answer.
Post 2 of 5
Re: Connection error
03-20-2017 04:26 AM in reply to: luca.buoninconti
@luca.buoninconti
Welcome to the community...
Mostly when you see this message..  Its linked to an incorrect time aspect on your computer operating system (or perhaps Autodesk is having an issue at their end which we can't do anything about)..   See this article and its solutions.  Good luck and report back on your progress.
 Mark Lancaster
  , Certified Professional in Autodesk Inventor 2014/2015/Exam & AutoCAD 2014 and not an Autodesk Employee
 Installation | Autodesk Virtual Agent | Autodesk Register Once | Activation/Chat | Microsoft FixitDesktop Sub-Grant User Access | Error 1603 | Autodesk Med Resolu LibrayInventor Reset | Screencast
 Kudos is much appreciated if the information I have shared is helpful to you and/or others
03-20-2017 08:59 AM in reply to: Mark.Lancaster
Thank you for your answer!
Unfortunately the problem is not solved, I hope it is a temporary problem with the Autodesk servers; I'll try again in the next few days :)
Post 4 of 5
03-20-2017 02:07 PM in reply to: luca.buoninconti
Hello @luca.buoninconti,
You can also check the proxy settings in this article. Establish an Internet connection to continue"
You can try a manual activation offline to activate instead.
Let us know how it goes. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha Laureiro
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall
03-22-2017 07:42 AM in reply to: natashal84
Post to the Community
New Post
