Hi, I'm installing 3ds max on my Mac using Windows7/Parallels but, during the first run of the, in the "Let's Get Started" window I can't enter my serial number (I got a teacher license) 'cause no new window appears. If I try to sign in, the "Connection Error" window appears and I can not do anything (the "Try again" button brings me to the "Connection error" window).
Please, help me!
Solved by luca.buoninconti. Go to Solution.
Welcome to the community...
Mostly when you see this message.. Its linked to an incorrect time aspect on your computer operating system (or perhaps Autodesk is having an issue at their end which we can't do anything about).. See this article and its solutions. Good luck and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thank you for your answer!
Unfortunately the problem is not solved, I hope it is a temporary problem with the Autodesk servers; I'll try again in the next few days 🙂
Hello @luca.buoninconti,
You can also check the proxy settings in this article. Establish an Internet connection to continue"
You can try a manual activation offline to activate instead.
Let us know how it goes.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi, thanks for your answer!
Without making any setting change, now 3ds max works!
I tried to start the program as an administrator, and this time it worked!
