Hi there
Went to install autocad2016 civils 3d on 64bit win10 and had failure, here is the contants of the install log file
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO === Setup started on DESKTOP-T7C9VJO by kmorr ===
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO Path_Length: 152
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO Current Directory C:\Autodesk\Autodesk_AutoCAD_Civil_3D_2016_Win_64bit_WI_en-us
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO Launch
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO CommandLine /akamai /sid SESSION_ID /skipEULA /trialMode /url "
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/Autodesk_AutoCAD_Civil_3D_2016_Win_64bit_WI_en-u...2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO Path_Length: 152
2016/3/5:17:28:06 kmorr DESKTOP-T7C9VJO Current Directory C:\Users\kmorr\AppData\Local\Temp\_AI262F.tmp
2016/3/5:17:30:07 kmorr DESKTOP-T7C9VJO === Setup ended ===
2016/3/5:17:34:52 kmorr DESKTOP-T7C9VJO Install Autodesk Material Library 2016 - Base Image Library Succeeded
2016/3/5:17:34:52 kmorr DESKTOP-T7C9VJO Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:34:56 kmorr DESKTOP-T7C9VJO Install Autodesk Content Service Succeeded
2016/3/5:17:34:56 kmorr DESKTOP-T7C9VJO Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:34:58 kmorr DESKTOP-T7C9VJO Install Autodesk Content Service Language Pack Succeeded
2016/3/5:17:34:58 kmorr DESKTOP-T7C9VJO Installing SQL Server CE 4.0 x64: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:41:53 kmorr DESKTOP-T7C9VJO Install ACA & MEP 2016 Object Enabler Succeeded
2016/3/5:17:41:53 kmorr DESKTOP-T7C9VJO Download Play C3D
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/C3D_x64.t...2016/3/5:17:42:14 kmorr DESKTOP-T7C9VJO Download Complete C3D
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/C3D_x64.t...2016/3/5:17:42:14 kmorr DESKTOP-T7C9VJO Installing Autodesk AutoCAD Civil 3D 2016 Core: INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Maestro\" TRANSFORMS="C:\Users\kmorr\AppData\Local\Temp\_AI262F.tmp\x64\C3D\C3D-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:42:35 kmorr DESKTOP-T7C9VJO Install Autodesk AutoCAD Civil 3D 2016 Core Succeeded
2016/3/5:17:42:35 kmorr DESKTOP-T7C9VJO Download Play C3D_LP
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/C3D_LP_x6...2016/3/5:17:43:13 kmorr DESKTOP-T7C9VJO Download Complete C3D_LP
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/C3D_LP_x6...2016/3/5:17:43:13 kmorr DESKTOP-T7C9VJO Installing Autodesk AutoCAD Civil 3D 2016 Core - English: INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Maestro\" TRANSFORMS="C:\Users\kmorr\AppData\Local\Temp\_AI262F.tmp\x64\en-us\C3D\C3DLP\C3DLP-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Maestro\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:59:12 kmorr DESKTOP-T7C9VJO Install Autodesk® AutoCAD® Civil 3D® 2016 - English Succeeded
2016/3/5:17:59:12 kmorr DESKTOP-T7C9VJO Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:17:59:14 kmorr DESKTOP-T7C9VJO Install SketchUp Import plug-in Succeeded
2016/3/5:17:59:15 kmorr DESKTOP-T7C9VJO Download Play CIVIL_OE64_SILENT
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/CIVIL_OE6...2016/3/5:18:01:02 kmorr DESKTOP-T7C9VJO Download Complete CIVIL_OE64_SILENT
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/CIVIL_OE6...2016/3/5:18:01:02 kmorr DESKTOP-T7C9VJO Installing Autodesk AutoCAD Civil 3D 2016 64 bit Object Enabler: "C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016\x64\support\ObjectEnabler\Civil3D_2016_OE_64Bit.exe" /q
2016/3/5:18:01:03 kmorr DESKTOP-T7C9VJO Install Autodesk AutoCAD Civil 3D 2016 64 bit Object Enabler Succeeded
2016/3/5:18:01:03 kmorr DESKTOP-T7C9VJO Installing FARO LS 5.2.0.35213: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:18:01:06 kmorr DESKTOP-T7C9VJO Install FARO LS 5.2.0.35213 Succeeded
2016/3/5:18:01:07 kmorr DESKTOP-T7C9VJO Download Play AUTODESK_RECAP
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/AUTODESK_...2016/3/5:18:04:06 kmorr DESKTOP-T7C9VJO Download Complete AUTODESK_RECAP
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/AUTODESK_...2016/3/5:18:04:06 kmorr DESKTOP-T7C9VJO Installing Autodesk® ReCap™: INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap 2016\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2016" SETUP_PACKAGECODE={D694030F-4F17-4224-8FD4-AED8361263D6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,.NET Framework Runtime 4.0,{66D83FE0-D798-4B38-86FE-FB48151E5AEF},;;;;" PACKAGEUPI={74267BE3-212B-4570-926F-CB875ECE4BAA} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/3/5:18:04:23 kmorr DESKTOP-T7C9VJO Install Autodesk® ReCap™ Succeeded
2016/3/5:18:04:23 kmorr DESKTOP-T7C9VJO Download Play SSA
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/SSA.tar.l...2016/3/5:18:10:43 kmorr DESKTOP-T7C9VJO Download Aborted SSA
http://trial2.autodesk.com/NET16SWDLD/2016/CIV3D/WI/{F81714B2-2F8E-43BC-A260-34D5F39235EB}/SSA.tar.l...2016/3/5:18:10:43 kmorr DESKTOP-T7C9VJO Install Autodesk Storm & Sanitary Analysis Failed Download Failed, Installation aborted, Result=1603
2016/3/5:18:10:44 kmorr DESKTOP-T7C9VJO Rollback FARO LS 5.2.0.35213 Succeeded
2016/3/5:18:10:44 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Civil 3D 2016 64 bit Object Enabler Failed Failure is ignored, Result=1619
2016/3/5:18:10:45 kmorr DESKTOP-T7C9VJO Rollback SketchUp Import plug-in Succeeded
2016/3/5:18:11:43 kmorr DESKTOP-T7C9VJO Rollback Autodesk® AutoCAD® Civil 3D® 2016 - English Succeeded
2016/3/5:18:11:45 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Civil 3D 2016 Private Pack Succeeded
2016/3/5:18:11:57 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Map 2016 - English Succeeded
2016/3/5:18:12:53 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Map 2016 Global Succeeded
2016/3/5:18:12:55 kmorr DESKTOP-T7C9VJO Rollback AutoCAD Architecture 2016 Language Shared - English Succeeded
2016/3/5:18:13:02 kmorr DESKTOP-T7C9VJO Rollback AutoCAD Architecture 2016 Shared Succeeded
2016/3/5:18:13:09 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Civil 3D 2016 Core - English Succeeded
2016/3/5:18:13:27 kmorr DESKTOP-T7C9VJO Rollback Autodesk AutoCAD Civil 3D 2016 Core Succeeded
2016/3/5:18:13:30 kmorr DESKTOP-T7C9VJO Rollback ACA & MEP 2016 Object Enabler Succeeded
2016/3/5:18:13:41 kmorr DESKTOP-T7C9VJO Rollback AutoCAD 2016 Language Core - English Succeeded
2016/3/5:18:15:19 kmorr DESKTOP-T7C9VJO Rollback AutoCAD 2016 Core Succeeded
2016/3/5:18:15:19 kmorr DESKTOP-T7C9VJO Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2016/3/5:18:15:20 kmorr DESKTOP-T7C9VJO Rollback SQL Server CE 4.0 x64 Succeeded
2016/3/5:18:15:24 kmorr DESKTOP-T7C9VJO Rollback Autodesk Content Service Language Pack Succeeded
2016/3/5:18:15:27 kmorr DESKTOP-T7C9VJO Rollback Autodesk Content Service Succeeded
2016/3/5:18:15:34 kmorr DESKTOP-T7C9VJO Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2016/3/5:18:15:46 kmorr DESKTOP-T7C9VJO Rollback Autodesk Material Library 2016 Succeeded
2016/3/5:18:15:46 kmorr DESKTOP-T7C9VJO Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Can anybody point to what is going wrong with this installation from the log files, thanks for any help and advice
