I'm trying to do a Civil 3d 2022 Custom install for a network deployment with a custom profile and for some readon the changes I have made on this custom profile don't work on the Civil 3d 2022 install. I'm checking that it's the correct shortcut that I am clicking on. It loads the default C3d Imperial profile. Here are the steps I took to create this install:
-Install Civil 3d 2022 manually and customize the C3d_Imperial profile with my companies customizations
-Export this profile to a network location
-Create the custom install in manage.autodesk.com with C3d 2022 and I have unchecked Create c3d imperial, metric, c3d as autocad options. (I also tried with checking these options and same result)
-Select the Custom profile and load it with the previously exported .arg profile
Everything installs good and only the custom C3d desktop shortcut gets created but it only loads the default imperial settings. These same steps work perfectly for Autocad 2022 but not for Civil 3d 2022.
Any input would be greatly appreciated!
Has anyone ran into a similar issue or does anyone see anything wrong with my settings?
