Installation & Licensing
Changing PC that Autocad is installed on
3 REPLIES 3
aaron
303 Views, 3 Replies
Please could you advise how we change the PC that AutoCad is installed on.
3 REPLIES 3
Mark.Lancaster
in reply to: aaron
@aaron
Welcome to the community..
Need more info like AutoCAD Version and license type?   Single User, Multi-user subscription, standalone perpetual or network perpetual.
Mark Lancaster
natasha.l
in reply to: aaron
Hello @aaron,
This article will briefly explain license types and how activation/licensing works from type to type: About License Types
Let us know if you have any more questions or you run into an issue.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
natasha.l
in reply to: aaron
Hello @aaron,
I would like to add to this post in case someone else visits this post. You can simply install the software on the new PC you wish to use and activate normally.
1. Locate & Use a Browser Download Method from Autodesk Account
2. Activation Options
  • Subscription software is primarily activated when a named user signs in to verify the license. Although a serial number and product key may be required, this information is often entered automatically, depending on your download and installation method.
  • Perpetual license software is activated by entering a serial number and product key and licensing it to run on a specific computer.  You can activate this type of license automatically, or manually by using the Digital Concierge to get your Autodesk activation code.
  • Education Software requires account creation on the Educational Community (Institutions should check their options)
Thank you for posting.
Administrator Productivity
