We changed the domain name of our network and servers, and are now having random issues with AutoDesk products.
¡Resuelto! Ir a solución.
Resuelto por christian. Ir a solución.
Hi !
If local admin and some users can run AutoDesk products and others not (same product in same version with enough licenses of course...), it is probably a connection / communication problem between the workstations concerned and the license server
Best regards
i recommend going through the above link but also can you ping the license server by name from the client machines?
DarrenP
Problems solved, checked all licensing options and found that the license file was not configured correctly for multiple licenses.
Thank you for your help
