Change Licensing from Network to Single-User
r_stanger
r_stanger
Community Visitor
Community Visitor
we have changed our licensing-agreement from network to single-user.
All users have an autodesk account and the products are correct assigned in the autodesk-management.
The old network-licence-service is deactivated.
When the users now start revit, the program shows a error-message (see attachments).
What can I do, to fix this problem.
DarrenP
you will have to reset the licensing: https://forums.autodesk.com/t5/installation-licensing/how-to-reset-autodesk-2020-2024-licensing/td-p...
DarrenP
mdavis22569
If it's 2023 and up .. try the Reset here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-local...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-change-or-r...
Mike Davis
Simon_Weel
Download the Licensingsupporttool. Unpack it. Execute
AdskLicensingSupportTool.exe --resetlicensemethod ALL:USER
on all machines and you've switched all installed Autodesk software (as of version 2017) to a User License. And if you have to switch back to network:
AdskLicensingSupportTool.exe --resetlicensemethod ALL:NETWORK
