Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
Change License Type to Single User While Network License is Borrowed
5 RESPUESTAS 5
RESUELTAS
Responder
Mensaje 1 de 6
emiller
1161 Vistas, 5 Respuestas
Is it absolutely necessary to return a borrowed network license prior to changing the license type to single user?
Eric
Etiquetas (1)
5 RESPUESTAS 5
Mensaje 2 de 6
mdavis22569
en respuesta a: emiller
If it's borrowed and you need it .. then yes, return it and then reset the license type to Sign In / Single - User.
Otherwise it might just hang out there.   The Server doesn't know it's been released...
Mike Davis
Mensaje 3 de 6
emiller
en respuesta a: mdavis22569
Michael,
Thank you for the response.  This is for a large scale migration (150 users) so my concern is more on any access issues for the user once IT switches them over.  If there's still a borrowed license hanging out there, would that cause issues for their new single user access?  Or would it be a license compliance issue?
Eric
Mensaje 4 de 6
TravisNave
It could end up being a compliance issue if the license was borrowed for an extended period of time beyond the typical 30-day allowance of crossover.  Are you retiring the NLM?  Or are you just moving some off the network license and onto named users?  You get a grace period but you don't want to abuse it.
Autodesk Forums:
Mensaje 5 de 6
emiller
Travis,
The NLM will be retired eventually.  This is a complete transition to named user.  Thanks for the information.  I think that's all I need at this point.  We'll plan on making sure all licenses are returned prior to the switch to avoid issues.
Eric
Mensaje 6 de 6
TravisNave
Glad to hear.  I have a script in my signature line hot button issues that can help streamline moving to named users from other licensed installs.
Good Luck!
Autodesk Forums:
Publicar en los foros
Administrator Productivity
