cant get eagle 9.6.2 to run after install
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
There seem to be lots of reports of eagle 9.6.2 not loading on computers.
Ive gone through all of them.
I'm frustrated as i see numerous users reporting the solutions that are posted do not work. Then the guy who is the administrator (garcia) checks that the problem is solved when its clearly not .
Usually when you go through enough of them you find one where someone posts the solution that will work and this is not the case here.
https://forums.autodesk.com/t5/eagle-forum/eagle-9-6-2-won-t-open/td-p/9860094
Hi I also disgusted from Eagle.
On clear installation Win 10, I wanted run Eagle, So I launch Eagle.Exe
And that was all.
After that I found "Solution"
- Navigate to C:\Windows\System32.
- Find the file IG4ICD64.dll and rename it in IG4ICD64.dll.bak.
- Launch Eagle.
If the issue persists or if the above DLL cannot be found, follow the below steps or the issue:
- Navigate to C:\EAGLE 9.x and find the file LIBEAY32.dll.
- Rename the .dll by appending .bak at the end of the file name: LIBEAY32.dll.bak.
- Launch Eagle again, the program should open with no issue.
IG4ICD64.dll never exist in folder System32! So i can not rename this file.
Next "Solution"
delete Eagle in AppData/Roaming evertime when i need Eagle
Eagle finally run, but only Offline. Eagle never goes to online state.
I'm paying you for something broken…
((((end of previous users comments)))
What is the real solution.? Can someone be serious about solving this problem?
I downloaded and installed Win64 OpenSSL v1.1.1i Light.
(needless to say i dont want unknown software on my computer as that is a security risk that you wouldnt know about)
renamed libeay32.dll and ssleay32.dll and replaced with version from SSL zip file
restart and it still fails
This is a brand new dell ailenware computer speced out for top of the line hardware.
I just updated the graphics card drivers and no luck (nvidia geforce RTX 3070) and also a AMD Radeon card
Basically, the first time i lauucnehd it, i got to where i type in my username and then hung up. After that point, I was never able to even restart it.
