Installation & Licensing
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
Post 1 of 4
Cannot uninstall maya
33 Views, 3 Replies
04-20-2017 04:50 PM
I have accidentally deleted the Maya folder, and so to get it back i needed to reinstall it, but when i start the setup it says that it is already installed, i have uninstalled it from the Programs and Features, i have deleted every single remaining folder that is related to Maya, or Autodesk, i have also deleted all the keys from the registry, and yet i still can`t install it.
Post 2 of 4
Re: Cannot uninstall maya
04-21-2017 05:56 AM in reply to: Tripl3ml
@Tripl3ml
During your attempt to reinstall, are getting a message indicating the software is already installed? Use Microsoft Fitix to ensure everything was uninstalled successfully. If you see the application within Microsoft Fixit, that would mean Windows still see installations files and you need to uninstall them.
For the Microsoft Fixit, use the link in my signature Manual Uninstall under Resources.
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution
Post 3 of 4
04-21-2017 09:21 AM in reply to: Darin.Green
It listed a bunch of programs which doesn't include Maya, so i chose "Not Listed" and now its asking for the product code, what should i do next?
Post 4 of 4
04-21-2017 09:40 AM in reply to: Tripl3ml
If Maya wasn't listed, close the application as it's fully uninstalled.
Can you post a copy of your installation log file from you temp directory? i.e. C:\Users\<username>\Appdata\Local\Temp
Post to the Community
New Post
