Announcements
Cannot start start AutoCAD 2023 after installation, dialog box says License Manager is not functioning or is improperly installed. AutoCAD will shut down now.
print.wise
print.wise
Community Visitor
Community Visitor
I’m hoping someone at Autodesk/AutoCAD can resolve an issue with my installation of AutoCAD 2023.
I enrolled in an AutoCAD course with the University of Guelph in the spring of 2022. The course 310-1035 Computer Assisted Design I started on May 6, 2022.
Unfortunately, due to family matters I withdrew from the course on July 30, 2022. Subsequently the program was disabled, and I deleted the program from my computer.
Later, I enrolled with Ryerson University (now Toronto Metropolitan University) for the course CKAR 215 Computer-Aided Architectural Drawing using AutoCAD.
The course started Sept. 15th and provided a link to download AutoCAD. I downloaded the program but have not been able to start the program. A dialog box appears stating License Error.
The License Manager is not functioning or is improperly installed. AutoCAD will shut down now.
Also, I received a letter from Autodesk stating that my educational expires on May 6, 2023 which makes me think they assume I am still using the program I downloaded for the UofG course.
I would think with the new course from TMU the expiry date should be around Sept. 15, 2023 or thereabouts.
Note: I used a different email address for the TMU course don't know if that affects the process.
To quote the Beatles: HELP!
P.S> I copied copied a couple of screen shots but i got a message saying invalid HTML in message so I deleted them.
karen_kirk
I had to uninstall the license and re-install the license app THEN update it.
mdavis22569
@print.wise
Make sure you have all of the following permissions / access:
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Which URLs/Protocols need to be white listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
Also look in your Autodesk Desktop App and make sure all of the updates for Autodesk and AutoCAD are installed
Mike Davis
