Hi all,
I cannot complete the installation process on my laptop (Acer Aspire E5-573 G) with Windows 10 64bit installed on it.
The problem I'm getting is the following:
1) I select the correct installation file to be downloaded
2) I start the installation process, the file starting getting download and after few second I get the generic error message. In addition, I can see these error log file:
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q === Setup started on LAPTOP-UQCI0L3Q by leonardo ===
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q Path_Length: 162
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q Launch
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup...
2017/1/15:13:45:10 leonardo LAPTOP-UQCI0L3Q Current Directory C:\Users\leonardo\AppData\Local\Temp\_AIB180.tmp
2017/1/15:13:45:16 leonardo LAPTOP-UQCI0L3Q === Setup ended ===
2017/1/15:13:45:11 leonardo LAPTOP-UQCI0L3Q === Setup started on LAPTOP-UQCI0L3Q by leonardo ===
2017/1/15:13:45:11 leonardo LAPTOP-UQCI0L3Q Path_Length: 162
2017/1/15:13:45:11 leonardo LAPTOP-UQCI0L3Q Current Directory C:\Users\leonardo\AppData\Local\Temp\_AIB180.tmp
2017/1/15:13:45:11 leonardo LAPTOP-UQCI0L3Q Launch
2017/1/15:13:45:13 leonardo LAPTOP-UQCI0L3Q Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/1/15:13:45:13 leonardo LAPTOP-UQCI0L3Q Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/1/15:13:45:13 leonardo LAPTOP-UQCI0L3Q Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\leonardo\AppData\Local\Temp\_AIB180.tmp\Setup\AcSetup.dll
2017/1/15:13:45:13 leonardo LAPTOP-UQCI0L3Q Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/15:13:45:15 leonardo LAPTOP-UQCI0L3Q PageOpen LaunchDialog
2017/1/15:13:45:39 leonardo LAPTOP-UQCI0L3Q PageOpen LicenseDialog
2017/1/15:13:45:39 leonardo LAPTOP-UQCI0L3Q PageOpen ProductInfoDialog
2017/1/15:13:45:39 leonardo LAPTOP-UQCI0L3Q PageOpen ProductSelectionDialog2
2017/1/15:13:45:52 leonardo LAPTOP-UQCI0L3Q PageOpen FullProgressDialog
2017/1/15:13:46:15 leonardo LAPTOP-UQCI0L3Q Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/1/15:13:46:17 leonardo LAPTOP-UQCI0L3Q Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/1/15:13:46:17 leonardo LAPTOP-UQCI0L3Q Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/1/15:13:46:17 leonardo LAPTOP-UQCI0L3Q Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/15:13:46:19 leonardo LAPTOP-UQCI0L3Q Install Universal C Runtime (KB3118401) Succeeded
2017/1/15:13:46:19 leonardo LAPTOP-UQCI0L3Q Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/1/15:13:46:19 leonardo LAPTOP-UQCI0L3Q Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\leonardo\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/15:13:47:46 leonardo LAPTOP-UQCI0L3Q Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/1/15:13:47:46 leonardo LAPTOP-UQCI0L3Q Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/1/15:13:47:46 leonardo LAPTOP-UQCI0L3Q Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\leonardo\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/15:13:49:09 leonardo LAPTOP-UQCI0L3Q Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/1/15:13:49:11 leonardo LAPTOP-UQCI0L3Q Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/1/15:13:49:11 leonardo LAPTOP-UQCI0L3Q Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/15:13:50:06 leonardo LAPTOP-UQCI0L3Q Install DirectX Runtime Succeeded
2017/1/15:13:50:17 leonardo LAPTOP-UQCI0L3Q Download Error Connessione scaduta. Riconnettersi al sito. CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup...
2017/1/15:13:50:17 leonardo LAPTOP-UQCI0L3Q Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/1/15:13:50:17 leonardo LAPTOP-UQCI0L3Q Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/15:13:50:17 leonardo LAPTOP-UQCI0L3Q Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/15:13:50:18 leonardo LAPTOP-UQCI0L3Q Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
I also tried other versions but I could not get any installation process completed, same error.
Any suggestion?
Many thanks
Leo
Solved by Alexander.Rivilis. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @Anonymous.autodesk.com!
Download the installation files from Autodesk Virtual Agent >>>click<<<, then start the installation from that local file(s).
- alfred -
It is due to problem with downloading Autodesk Material Library 2017 from web installer. My recommendation is download full installation package of AutoCAD 2017 with help of Autodesk Virtual Agent and install it.
Instruction: Installing Autodesk products from the Virtual Agent
Hope this help you!
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Thank you, it worked!
Now I have to understand how to get my Student license and activate it 🙂 Thanks
