Hello
I can't install extension 1 for plant3d 2016 - 64bits, english, despite i'm suscriptor
"This update could not be installed becouse it is not designed for the version of Autodesk AutoCAD Plant 3D 2016 Core that is installed on your computer"
I've checked if i've installed a servipack before this, but windows doesn't show any for plant 2016. It only shows plant2015 SP2 (installed one year ago).
My plant2016 version is 7.0.49.04
I need to use dim reference on iso, only included in extension
Thanks in advance
Solved by JUANCARLOSBLASCO4129. Go to Solution.
Hi, JUANCARLOSBLASCO4129 , thanks for your post. So, I need to uninstall plant 3D SP2 for 2015 to install plant 3D Ext1 for 2016 ???? I got the same error and don't have any 2015 software installed, only 2016, 2014 and 2012!!
Not.
You must uninstall p3d service packs from 2016 versions
From what i remember, extensions and servicepacks need to be installed in release order.
Try to uninstall sp2 for plant3d 2016, then try.
If it dosen't work, try to uninstall sp1 from p3d 2016 also.
i hope it works for you
Thanks for your quick answer,
Are there any solutions to this last post?
I,too, don't have any service packs or extensions
installed for Plant 3D 2016!
Hello @Anonymous,
Please Create a New Post and include an error message, log file or issue you are facing with your reply to better assist you.
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
