Hi guys,
I recently bought a new laptop but now I struggle with installing Inventor. (Eduational License)
My specs are better than recommended so that shouldn't be the problem.
When I try to start Inventor after installation I get the message as in the attachment. I've tried installing Inventor 2014, tried troubleshooting it, re"installed it, after that deeted everything completety and installed 2013 and I still get the same error.
Anyone got the solution?
Specs:
Windows 8.1
16 GB DDR3
Inter i7 processor 2,4 GHz
GeForce GT 745M, 4GB dedicated VRAM
Thanks in advance for helping!
If you hit Alt Print Screen - you can capture just the dialog box and not the entire screen for attaching here.
I have seen special instructions for installation on Win 8.1 (a search might turn these up).
But at this point I think you will have to do a clean uninstall before attempting a new install.
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
Make sure you install Service Pack 1 and Update 2 for SP1.
Thanks a lot, this might help!
JJust 2 quick questions about the service pack
1. For Inventor 2014 i can only find SP1, I can't find SP1.1, is it correct that this is only aplicable for 2013?
2. Do I download and install Inventor first, or do I run the servicepack first? (Iguess the first option)
Thanks in advance
