Installation & Licensing
can't install AutoCAD LT 2009 on 64-bit
2 REPLIES 2
sanaea
1002 Views, 2 Replies
2 REPLIES 2
chriscowgill7373
in reply to: sanaea
My understanding 2009 will not run on a 64bit OS, you can however try the suggestions in this post:
Https://forums.autodesk.com/t5/autocad-lt-forum/i-need-the-autocad-lt-209-installer-for-64-bit-win-7...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
TravisNave
in reply to: sanaea
AutoCAD LT 2009 is long retired.  Even if you could get it installed, it would almost certainly have compatibility issues and it would not activate.  Is there any reason you can't just get the latest version?
Autodesk Forums:
Administrator Productivity
