I went in C:\Program Files (x86)\Common Files\Autodesk Shared\Uninstall Tool\R1\UninstallTool.exe.. But was not there the 'Uninstall the libraries in the following order: Autodesk Material Library Medium Resolution Image Library Autodesk Material Library Low Resolution Image Library Autodesk Material Library Base Resolution Image Library Autodesk Material Library'
What can I do now?
Regards
Janine
Hello @jmb.janine,
You do not have this tool because of the type of download (install now) it does not contain this media folder. To resolve this issue I would try another method of download that maybe the true issue in your case.
Please run through these steps:
Let us know how it goes.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
