Installation & Licensing
Can't activate autocad lt 2021
5 REPLIES 5
rob.logan
3261 Views, 5 Replies
I have just tried to install autocad lt 2021. Before I did it I uninstalled previous versions and tried to delete old programme data to free up space on my machine. Now, when autocad launches I get this error message:
"the license manager is not functioning or is improperly installed. AutoCAD LT will shut down now, ADLSDK_STATUS_AUTH_PENDING
3:user canceled authorization"
I'm also having the exact same issue with revit. I've tried (several times) reinstalling the software, and reinstalling the License Manager. Nothing works. Can anyone help?
Tags (2)
Labels (1)
5 REPLIES 5
in reply to: rob.logan
RobDraw
You may have not completely uninstalled the older software data. Since this is affecting multiple programs I would uninstall all of them following the directions here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Clean-...
and start with fresh installs.
You may be able to fix your problem by deleting the folders not removed by uninstallation but who knows what kind of damage you have done by uninstalling and reinstalling multiple times.
Rob
Tiana_Y
Hi @rob.logan
Thank you for posting here in the Forums! I am just checking in to see if the suggestions that @RobDraw and @Anonymous provided helped you resolve the issue. If you still need assistance let us know and we are more than happy to help!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
rob.logan
Thanks for such a quick response - I tried uninstalling and installing one last time and the software ended up installing properly in the end. Will have a look through the thread though.
in reply to: Tiana_Y
help downloading for autocad 2021 our drawing practic
Administrator Productivity
