Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Can I install plain AutoCAD standalone with a AutoCAD Mechanical serial number
I have a multseat standalone license for AutoCAD Mechanical... however I need to install plain AutoCAD.  Will a plain AutoCAD install and activate properly with an AutoCAD Mechanical serial number?  Also is there a way to downgrade licensing from Mechanical to plain AutoCAD so I don't have to pay the higher subscription fee for Mechanical... we don't need any Mechanical features.
DarrenP
no the serial numbers are tied to specific product and version
yes you can downgrade talk to your reseller for pricing info
DarrenP
TravisNave
Darren is right.  In the mean-time, you can still launch vanilla AutoCAD icon.  It is in the Mechanical program group.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks for the info.  One more question.  It is my understanding that with "Cascading Licensing", if I have a network license of AutoCAD Mechanical and I launch Plain AutoCAD from a workstation it will first look for an AutoCAD license on the server, if none are available, it will then pull the license needed from the AutoCAD Mechanical license.  Is this correct?
TravisNave
This is generally correct depending on the release and the suite.
Autodesk Forums:
