Can I install Multiple Revit versions?
Hello, I currently have the 2019 version of revit. The firms I am working with are using revit 2018. Is it possible to download the 2018 version even if I have the 2019 version?  Thank you
title renamed for clarity by @Viveka_CD to 'Can I install Multiple Revit versions?'
On Subscription you have access to the previous 3 versions.  So go to manage.autodesk.com and you should see 2018 available for download.  If not, you can request it from Autodesk Support by clicking the Support button on the top right corner of the page.
If you are still on demo though, you can request it from ava.autodesk.com.  Just ask for Revit 2018 download.
PrathapSekar
@Anonymous, @my previous firm we had four versions, and my senior had five versions installed.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! Thanks for posting on the forums Smiley Happy
Yes, you can install multiple versions on Revit on the same machine, provided it meets the system requirements and the hardware specifications for successfully working on the applications.
You'll have to watch out for backward compatibility and licensing issues if you have limited licenses.
Let me know if you have any questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Radish_G
Hi @Anonymous,
Which means if I have a subscription license for Revit 2020, I can install Revit 2017, 2018 & 2019 as well.
Am I correct?
Regards
Radish G
ennujozlagam
yes..thanks
Mark.Lancaster
@Radish_G
Just to add..  In about 3 to 4 months the 2021 version will be released and the 2017 version will be retired and no longer a version entitlement.  Meaning installing the 2017 version now not worth the time.
Mark Lancaster
