I have tried multiple times to download, install.uninstall, but i still am getting errors, not allowing me to download. I noticed the error when I opened Revit afterwards, and the publish button was missing and the 360 cloud button did not function.
Solved by natasha.l. Go to Solution.
@Anonymous
Sorry for your troubles with installing. Have you tried installing with your anti virus and User Account control settings temporarily disabled?
http://windows.microsoft.com/en-us/windows/turn-user-account-control-on-off#1TC=windows-7
Are you running Windows 10 or 10 Pro with Fall Creator Update...the update doesn't play nice with C4R.
Try a clean uninstall of Revit 2016
then uninstall/disable .NET and C++ files
then install Revit 2016
then install updates with C4R via Desktop App
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hello @Anonymous,
In addition to everyone's questions & recommendations. Please let us know where you located your download & which download you selected. Please try the steps below
Review this information Autodesk Collaboration for Revit 2016.
Note:
Prior to installing Autodesk Collaboration v9 for Revit 2016 add-on, please verify that you have already installed Autodesk Revit 2016. Autodesk Revit 2016.1.8 Update is required to use Autodesk Collaboration v9 for Revit 2016. The Autodesk Collaboration v9 for Revit 2016 install will apply Autodesk Revit 2016 R2 and 2016.1.8 Update as needed.
*Allow ~20 seconds for the installer to detect your Autodesk Revit 2016 version before choosing the Install button.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
thanks for all the help. I ultimately had my IT person help me with uninstalling/installing, turning off security settings, deleting temp folder, etc. He was still getting fail errors. He finally just uninstalled Revit completely, and then installed the R2 version. Afterwards he then upgraded to the newest release.
I just opened up Revit and everything seems to be in place and I am now able to publish and see the other Collaboration tools! Thanks for all the help.
