Installation & Licensing
Autodesk Revit Installation Stalled
2 REPLIES 2
mikeg12
296 Views, 2 Replies
I have the .net framework already on my computer, and closed all other applications.  I made it through all the steps and selected what to install, pressed install and it seemed to be working...until it got to here and never went further.  As you can see the pause download is greyed out as if it never even started.  The "installing..." bar on top is moving so it's not frozen but nothing else is changing. I've left it like this for a while and still nothing.
Any idea what could be going wrong?
2 REPLIES 2
TravisNave
in reply to: mikeg12
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
mikeg12
in reply to: TravisNave
That worked, thanks!
Administrator Productivity
