Installation & Licensing
Autodesk Maya 2017Licensing Error
2 REPLIES 2
aghazada.1672479
542 Views, 2 Replies
I get an error when trying to start maya:
maya: Autodesk Maya 2017Licensing ErrorA licensing error occurred that Autodesk systems were not able to handle for you. Please contact Autodesk Customer Support for help in resolving this error.GetFeatureAuthorizationStatus 1 (Failure)
I have installed ntp and it is running. My internet connection seems fine. But I still see this error.
My linux distribution is ArchLinux and I have installed and reinstalled the program from Aur.
Please help me!!
2 REPLIES 2
Make sure your date and time, timezone, and Daylight Saving Time settings are all correct.  If the time is off, your software will not license.  This happens more frequently around Daylight Saving Time, which just occurred.  It's possible that just verifying your time and maybe syncing with a internet time server will correct your issue.
Good Luck!
Autodesk Forums:
Hello @aghazada.1672479,
Do you have a subscription plan and not have access to activate any other way?
Please keep us posted. Thank you.
Administrator Productivity
