Go ahead and change over ...
Install the new software and try activating it ..
You can try using the License Transfer Utility if you're on perpetual .. but I would just try installing and activating first and then see if you have any issue
If you do, then use AVA (Autodesk Virtual Agent) to help with the activation:
Here is a link to it:
