When I'm trying to open a download it simply shows me an unknown error. I couldn't find any solution on google or here.
Solved by natasha.l. Go to Solution.
Welcome to the Autodesk User's Community..
There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @theodore.trokhymenko,
This issue could be due to several things but as mentioned try a differnt method & prepare your system before hand. Please follow the steps below:
Let us know if you are still having the issue.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
