HI there! Below is the whole report....I am getting so frustrated.....
2017/2/27:12:11:50 jennn DESKTOP-DNVCU4A === Setup started on
DESKTOP-DNVCU4A by jennn ===
2017/2/27:12:11:50 jennn DESKTOP-DNVCU4A Path_Length: 155
2017/2/27:12:11:50 jennn DESKTOP-DNVCU4A Current Directory
C:\Autodesk\Building_Design_Suite_Ultimate_2016_r2_English_Win_32_64bit_wi_en-us
2017/2/27:12:11:50 jennn DESKTOP-DNVCU4A Launch
2017/2/27:12:11:50 jennn DESKTOP-DNVCU4A CommandLine /PK 766H1 /SN
xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/Building_Design_Suite_Ultimate_2016_r2_Englis..."
C:\Users\jennn\AppData\Local\Temp\_AI7C92.tmp
2017/2/27:12:11:59 jennn DESKTOP-DNVCU4A === Setup ended ===
2017/2/27:12:11:51 jennn DESKTOP-DNVCU4A === Setup started on
2017/2/27:12:11:51 jennn DESKTOP-DNVCU4A Path_Length: 155
2017/2/27:12:11:51 jennn DESKTOP-DNVCU4A Current Directory
2017/2/27:12:11:51 jennn DESKTOP-DNVCU4A Launch
2017/2/27:12:11:58 jennn DESKTOP-DNVCU4A Download Skipped SETUPMARKER
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/SETUPM...2017/2/27:12:11:58 jennn DESKTOP-DNVCU4A Download Skipped SETUP_CONFIG
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/SETUP_...2017/2/27:12:11:59 jennn DESKTOP-DNVCU4A PageOpen LaunchDialog
2017/2/27:12:14:13 jennn DESKTOP-DNVCU4A PageOpen LicenseDialog
2017/2/27:12:14:13 jennn DESKTOP-DNVCU4A PageOpen ProductInfoDialog
2017/2/27:12:14:13 jennn DESKTOP-DNVCU4A PageOpen ProductSelectionDialog2
2017/2/27:12:14:36 jennn DESKTOP-DNVCU4A PageOpen FullProgressDialog
2017/2/27:12:14:40 jennn DESKTOP-DNVCU4A Download Play STARTMARKER
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/STARTM...2017/2/27:12:14:40 jennn DESKTOP-DNVCU4A Download Complete STARTMARKER
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/STARTM...2017/2/27:12:14:40 jennn DESKTOP-DNVCU4A Download Skipped VCREDIST2005X86
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:14:40 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Building Design Suite
Ultimate 2016\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a
/T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn
/l*v C:\Users\jennn\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/2/27:12:14:59 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2005
Redistributable (x86) Succeeded
2017/2/27:12:14:59 jennn DESKTOP-DNVCU4A Download Skipped VCREDIST2005X64
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:14:59 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Building Design Suite
Ultimate 2016\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a
/T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn
/l*v C:\Users\jennn\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/2/27:12:15:15 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2005
Redistributable (x64) Succeeded
2017/2/27:12:15:16 jennn DESKTOP-DNVCU4A Download Skipped
VCREDIST2012X86UPD4
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:15:16 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Building
Design Suite Ultimate 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe"
/install /quiet /norestart /log
C:\Users\jennn\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/2/27:12:15:20 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2012
Redistributable (x86) Update 4 Succeeded
2017/2/27:12:15:20 jennn DESKTOP-DNVCU4A Download Skipped
VCREDIST2012X64UPD4
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:15:20 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Building
Design Suite Ultimate 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe"
C:\Users\jennn\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/2/27:12:15:23 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2012
Redistributable (x64) Update 4 Succeeded
2017/2/27:12:15:24 jennn DESKTOP-DNVCU4A Download Skipped
VCREDIST2005SP1ATLX86
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:15:24 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2005 SP1 Redistributable ATL Security Update (x86):
"C:\Autodesk\WI\Autodesk Building Design Suite Ultimate
2016\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a
2017/2/27:12:15:49 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2005
SP1 Redistributable ATL Security Update (x86) Succeeded
2017/2/27:12:15:49 jennn DESKTOP-DNVCU4A Download Skipped
VCREDIST2005SP1ATLX64
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/VCREDI...2017/2/27:12:15:49 jennn DESKTOP-DNVCU4A Installing Microsoft Visual C++
2005 SP1 Redistributable ATL Security Update (x64):
2016\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a
2017/2/27:12:16:09 jennn DESKTOP-DNVCU4A Install Microsoft Visual C++ 2005
SP1 Redistributable ATL Security Update (x64) Succeeded
2017/2/27:12:16:10 jennn DESKTOP-DNVCU4A Download Skipped RVT
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/RVT.ta...2017/2/27:12:16:10 jennn DESKTOP-DNVCU4A Installing Autodesk® Revit® 2016:
TRANSFORMS=":en-us.mst;:all.mst;C:\Users\jennn\AppData\Local\Temp\_AI7C92.tmp\x64\RVT\RVT-standalone.mst"
ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building
Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\"
FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/27:12:20:52 jennn DESKTOP-DNVCU4A Install Autodesk® Revit® 2016
Succeeded
2017/2/27:12:20:52 jennn DESKTOP-DNVCU4A Download Skipped STEEL
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/STEEL_...2017/2/27:12:20:53 jennn DESKTOP-DNVCU4A Installing : ADSK_EULA_STATUS=#1
MUILANG=en-us SETUP_PACKAGENAME="Autodesk Building Design Suite Ultimate
2016" SETUP_PACKAGECODE={B1FDF4CC-20D6-4036-97B7-C12AA9682C4F}
SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0
SETUP_PRODUCTDEPENDENCIES=";;;;"
PACKAGEUPI={387CDD37-0549-4FF6-BFC6-F3FB1FF21629}
ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Building Design Suite Ultimate
2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/2/27:12:20:55 jennn DESKTOP-DNVCU4A Install Autodesk Workflows 2016
Succeeded
2017/2/27:12:20:55 jennn DESKTOP-DNVCU4A Download Skipped CM
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/CM.tar...2017/2/27:12:20:55 jennn DESKTOP-DNVCU4A Installing Autodesk® Material
Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us
SETUP_PACKAGENAME="Autodesk Building Design Suite Ultimate 2016"
2017/2/27:12:21:06 jennn DESKTOP-DNVCU4A Install Autodesk® Material
Library 2016 Succeeded
2017/2/27:12:21:07 jennn DESKTOP-DNVCU4A Download Skipped CMILB
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/CMILB....2017/2/27:12:21:07 jennn DESKTOP-DNVCU4A Installing Autodesk® Material
Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us
2017/2/27:12:21:15 jennn DESKTOP-DNVCU4A Install Autodesk® Material
Library 2016 - Base Image Library Succeeded
2017/2/27:12:21:15 jennn DESKTOP-DNVCU4A Download Play CMILL
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/CMILL....2017/2/27:12:22:01 jennn DESKTOP-DNVCU4A Download Aborted CMILL
http://edutrial.autodesk.com/NET16SWDLD/2016/BDSADV/WI/{FB034848-2F6A-4A7A-90C5-E17FBAB7290A}/CMILL....2017/2/27:12:22:01 jennn DESKTOP-DNVCU4A Install Autodesk® Material Library
2016 - Low Image Library Failed Download Failed, Installation aborted,
Result=1603
2017/2/27:12:22:09 jennn DESKTOP-DNVCU4A Rollback Autodesk® Material
2017/2/27:12:22:21 jennn DESKTOP-DNVCU4A Rollback Autodesk® Material
2017/2/27:12:23:08 jennn DESKTOP-DNVCU4A Rollback Autodesk® Revit® 2016
Succeeded
2017/2/27:12:23:08 jennn DESKTOP-DNVCU4A Rollback Microsoft Visual C++ 2005
SP1 Redistributable ATL Security Update (x64) Failed Installation aborted,
Result=1619
SP1 Redistributable ATL Security Update (x86) Failed Installation aborted,
Result=1619
2017/2/27:12:23:09 jennn DESKTOP-DNVCU4A Rollback Microsoft Visual C++ 2012
Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2017/2/27:12:23:09 jennn DESKTOP-DNVCU4A Rollback Microsoft Visual C++ 2005
Redistributable (x64) Failed Installation aborted, Result=1619
Redistributable (x86) Failed Installation aborted, Result=1619
Jenn Proctor
