n
please help me to resolve this error..as i m in urgency to use this product for my study
Welcome to the community..
An image of a failed installation is no use to us..However in that same message of a failed installation, is a link to your installation log file. That's crucial in determining the root cause of a failed installation. At this point we can only speculate what the issue is.. So post your installation log file if you are still having an issue or I will assume its just failing due to the method you're using to install. I will share this information in the hopes that it will get your application installed.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
