Autodesk Application Manager
info
info
Every time I start up the computer this message appears:
I have tried some thinks, like uninstall Autodesk Application Manager. When I restart de computer the message is gone.
I have already made a new installation of Autodesk Application Manager, then the massage appears again.
This error message appears after an update of the Application Manager, a few day ago.
Does anyone else have the same problem.?
Does anyone know how to solve this problem.?
Replies (42)
hello
i have the same problems too.
the aam works with admin privileges and doesn'twork without this privileges.
who has a solution to this problem?
Solution 1 :
- Do not start AAM with Windows
- Start it manual, by "Right clic" > "Run as administrator"
- Enter password if needed.
Solution 2 :
If you have administrator (or Power user) privileges on your PC (Windows session) :
- Access to the "Start Menu" folder, and locate the AAM Shortcup.
On my PC, this folder :
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Application Manager\Autodesk Application Manager.lnk"
- Right-clic on the shortcut (.lnk file) > Properties
- Go to Compatibility tab
- Check the "Run this prgramm as administrator" (or something like that) box.
Each time Windows will launch this application, it will use this shorcut. The AAM will automaticaly starts with administrator privileges.
Does it helps ?
no. it doesn't help
i had tried it already before i had wrote the problem here
i got this problem with the new aam
the older versions worked without problems.
Quote: "" Solution 1 : - Do not start AAM with Windows - Start it manual, by "Right clic" > "Run as administrator" - Enter password if needed. "" I use this approach as a temporary solution. The problem persists when using a standard user account in Windows, here Windows 8.1 and 7. The AdAppMgrSvc.exe is present, version 5.0.142.0. The Service is up and running, error persist with standard user account. Before i updated the AAM to Version 5.0.142.0 it has worked without problems with a limited (standard) account. Is a final solution available for standard account users ? regards a.schier
Solution 1 :
> doesn't help
Solution 2 :
session) :
> doesn't work
box.
> doesn't work
> no
Does it helps ?
no, it doesn't help, but thank you for your answer
guillaumeboucher6709
Hi all, is there any news on the subject. Yesterday I deployed the Autodesk ECS 2016 Ultimate on our computers only to discover the AAM bug. It even happens, on multiple computers, when I log in on a computer with an account which has the admin privilege. The AAM error popup still appear. We are running Windows 7 Ent SP1 x64 French and we are a school so it's not in our best interest to give our students admin privilege. And I would very much prefer if I didn't have to disable or modify the permissions on the AAM. Thanks in advance for your help! Guillaume
Hello
for the moment there is only a temporary solution until an Update for the AAM is available from Autodesk.
You´ve got to start the AAM manualy with Admin rights local on each PC.
And from Autodesk we don't hear anymore to the Problem with the AAM...
Regards
a.schier
@guillaumeboucher6709 just remove AAM temporarely from autorun
I think I will do that. Thanks for the information Guillaume
Yes, works with admin, thanks
Do Autodesk staff have any idea when this will be fixed?
I work in big company, and can't have administrator previleges granted, so my AAM still won't work.
Tried to uninstall and install again.
ukdxb012
Please refer to the following useful Autodesk Knowledge Network Article's...
Autodesk Application Manager FAQ's - http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Application-Mana...
How to Silently Uninstall Application Manager using SCCM - http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-Silently-Uninstall...
I have also provided you with a link below to my Autodesk Screencast on 'How to uninstall and reinstall Autodesk Application Manager'
If you are having issues with permissions etc, please refer to the following useful Autodesk Knowledge Network Article's...
Unable to run Autodesk Application Manager - http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-U...
Unable to get updates as server is not reachable - http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodes...
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Still notnig. Have you fixed it yet?
So it's solution, but problem isn't fixed. I can't grant myself admin previleges.
So I have to wait for some Application Manager update
Thanks for tip, happily01, but it's not your solution, it's mine... Smiley Wink
Please read the full post and find the answer of the article on page 2.
thanks, helped a lot!
Hello there,
I should probably open a new topic for this problem, but it could be the same as original poster's one.
I can't manage to make the application run, even with use of admin mode on the AdAppMrg.exe (5.0.142.14)
I get this message:
"C:\Program Files (x86)\Common Files\Shared\AppManager\R1\AdAppMgrSvcStub.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0xc000012f. "
I tried to reinstall but he cant install on a "newer" version, so I try to unistall first with config panel and get
"Installer payload initialization failed. This is likely due to an incomplete or corrupt download file."
Ok lets go to windows support too ! I try the fixit app, but it doesn't find the AAM in my programs at all !
I also found myself in the limbs of the registry looking for an authorization mistake, so,
execute "regedit",
HKEY_LOCAL_MACHINE, SOFTWARE, Microsoft, Windows, CurrentVersion, Uninstall.
And there, i find infos about all my programs, even revit and other autodesk stuff, but nothing about the AAM 😞
So here i am, where do I go next ?
Thank you very much for trying to help.
You can create a batch file (.bat) with these ligns :
@Anonymous off
cls
call taskkill /F /IM "AdAppMgr.exe"
net stop AdAppMgrSVC
RD %Programdata%\Autodesk\SDS /S /Q
call "C:\Program Files (x86)\Common Files\Autodesk Shared\AppManager\R1\removeAdAppMgr.exe" --mode unattended
pause
(change the path if necessary)
Turn UAC off, quit antivirus.
Save locally the batch, run as admin. I will uninstall AAM.
Does it works ?
