Hello there,
I should probably open a new topic for this problem, but it could be the same as original poster's one.
I can't manage to make the application run, even with use of admin mode on the AdAppMrg.exe (5.0.142.14)
I get this message:
"C:\Program Files (x86)\Common Files\Shared\AppManager\R1\AdAppMgrSvcStub.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0xc000012f. "
I tried to reinstall but he cant install on a "newer" version, so I try to unistall first with config panel and get
"Installer payload initialization failed. This is likely due to an incomplete or corrupt download file."
Ok lets go to windows support too ! I try the fixit app, but it doesn't find the AAM in my programs at all !
I also found myself in the limbs of the registry looking for an authorization mistake, so,
execute "regedit",
HKEY_LOCAL_MACHINE, SOFTWARE, Microsoft, Windows, CurrentVersion, Uninstall.
And there, i find infos about all my programs, even revit and other autodesk stuff, but nothing about the AAM 😞
So here i am, where do I go next ?
Thank you very much for trying to help.
