Installation & Licensing
cancelar
Mostrando los resultados de
Quiere decir:
Autodesk activation, white page and not loading all applications.
1 RESPUESTA 1
Responder
Mensaje 1 de 2
kyle.reid72U6N
855 Vistas, 1 Respuesta
Autodesk Education chat has referred me here advising this is the place the place to get technical assistance, if there is a more suitable escalation path please let me know.
Symptoms are identical and well documented by the below post, please review their screenshots.
https://forums.autodesk.com/t5/installation-licensing/autocad-2021-licensing-script-errors/td-p/1003...
Context
We are transitioning 200+ sites that used to be managed under Autodesk central licenses for each product to having to request and manage their own education licenses. In December we ran a pilot program with 10 sites with no issues activating Autocad, Inventor, Revit licenses etc, 2 months later with the rollout it looks like all sites are getting stuck at that same white page as mention. Note: The script errors were always present and you would sometimes see 903 or timeouts but re-trying got the page to load.
Powershell command used to license the product (Works with no issue, only issue is the initial activation)
- "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" register --prod_key $SpecifiedProdKey --prod_ver $ProdVer --config_file $pit --eula_locale 'aus' --lic_method 'standalone' --from_deployment --serial_number $schoolLicence
What's change on our side: (Nothing)
- No Group policy changes to IE
- Machines where activation previously worked no longer work as well. (Uninstalled and tested with an un-activated license)
- Same install files (We deploy our software via SCCM and the install files are from 30/11/2020)
What's been tested
- Personal machine - Works
- Department machine (Our image)
--- Windows version 1809 - White screen
--- Windows version 1709 - White screen
--- Fresh Windows 1709 machine before joining to our AD (So no Group policy) - White screen
- Off our network on a departmental white screen - white screen
- Right click on the white page > Properties > shows the page is loading https://accounts.autodesk.com/logon? > Checked a wireshark to confirm nothing funky like Http 500's on Autodesk side
- If you use an invalid serial the page prompts to enter a serial, once you correct it - White screen
Additional troubleshooting
- Tested the below with no change.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
- Old advice but tried anyway
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Regist...
If anyone can provide some advice or a possible workaround that does not rely on the use of a personal device that would be appreciated.
Etiquetas (1)
1 RESPUESTA 1
Mensaje 2 de 2
kyle.reid72U6N
en respuesta a: kyle.reid72U6N
Bump.
I'm still looking for any guidance or clarification from Autodesk on this matter.
Out current workaround.
1. Run the program first and exit the script page
2. Go to https://registeronce.autodesk.com/prodreg?_ga=2.194189672.457568791.1612826709-668780743.1612826709
3. Log in with your Autodesk account
4. Enter your serial number
5. When you get to the Enter Product Request Code prompt go to C:\ProgramData\Autodesk\AdskLicensingService\Log
6. Open the ACD2021en_USRegInfo.html (for autocad 2021) and copy the Request code into the web page (as one line with single spaces)
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
