Issue: You are having a download failure error, similar to previous releases, that are causing installation errors of your 2018 product. However, the Autodesk Virtual Agent does not yet list the products available for 2018.
Work-Around: Until the Virtual Agent is updated, we collective peers will try to provide Official direct download links from Autodesk. This list may be updated as needed and links may or may not work as products are released. You can also try the Browser Download method from your Autodesk Accounts Management page.
If you have an official direct download link, that is tested and working, or have a URL of a direct download link that should work once the products are released, then please feel free to update the links in the comments below. Please only use official Autodesk links. Piracy is not tolerated here.
AUTODESK 2018 DIRECT DOWNLOAD LINKS
AutoCAD 2018
English 32 bit
English 64 bit – Part 1
English 64 bit – Part 2
AutoCAD LT 2018
English 32 bit
Inventor Professional 2018 x64
Part 1
Part 2
Part 3
Revit Live 2018
Navisworks Manage 2018
Part 1
Part 2
Navisworks Simulate 2018
Part 1
Part 2
More to come soon...
Solved by TravisNave. Go to Solution.
Solved by DarrenP. Go to Solution.
Solved by Darin.Green. Go to Solution.
Please, try to keep this topic up-to-date by adding VA missing links (e.g Simulation ones, Moldflow Synergy, Simulation Mechanical, Helius, etc.)
Mark Lancaster
& Autodesk Services MarketPlace Provider
moldflow synergy 2018 download :http://pan.baidu.com/s/1gfJxat9 heliu download : http://pan.baidu.com/s/1miyUaIO code :bybn
new download : Autodesk Moldflow Insight Ultimate 2018 : http://trial2.autodesk.com/NET18SWDLD/2018/MFIA/AE2C73D6-FFB6-42DC-BED3-3AFBB525F0F3/SFX/MFIA_2018_F... Autodesk Moldflow Synergy (two package) : http://trial2.autodesk.com/NET18SWDLD/2018/MFS/B1933A52-73A6-4020-919A-F8100652AF98/SFX/MFS_2018_FCS...
Anyone got the links for Autodesk Plant Design Suite Ultimate 2018 (x64) trial?
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
Hi all!
To amend this great list, I have links for Vault Workgroup 2018:
Thank you Tania of the most excellent Autodesk support team!
Sincerely,
Francisco
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
Any chances we can get Delcam 2018 links (possibly Ultimate editions)? Virtual Agent got 2017 only.
These links didn't work.....
Ahhhh I see now... Thanks Travis 🙂
Hello, I'm looking for the download links in virtual agent for the vehicle tracker... I can't find them (in which category are they???), and the links in this thread don't work either. I'm using autocad civil 3d 2017. Thanks for the help.
This posting was provided as a temporary location for the 2018 products until that version was available in the Autodesk VIrtual Agent. In addition the links have a timeout period and I think its only good for 30 days once the link is copied. One final thing.. Vehicle Tracker is not a common Autodesk product and will not be on the Autodesk Virtual Agent. You will have to download through your Autodesk Account (meaning not all applications are up there). Just make sure to your the browser download method and your popup blocker is not enabled in your browser.
Mark Lancaster
If you don't see it in your account, you can download from
https://www.autodesk.com/products/vehicle-tracking/free-trial
That's the web install, which doesn't work on my pc due to a proxy setting.
