Installation & Licensing
Autodesk 2018 Direct Download Links (Until Available on Virtual Agent)
123 REPLIES 123
Message 1 of 124
TravisNave
211784 Views, 123 Replies
Issue:  You are having a download failure error, similar to previous releases, that are causing installation errors of your 2018 product.  However, the Autodesk Virtual Agent does not yet list the products available for 2018.
Work-Around:  Until the Virtual Agent is updated, we collective peers will try to provide Official direct download links from Autodesk.  This list may be updated as needed and links may or may not work as products are released.  You can also try the Browser Download method from your Autodesk Accounts Management page.
If you have an official direct download link, that is tested and working, or have a URL of a direct download link that should work once the products are released, then please feel free to update the links in the comments below.  Please only use official Autodesk links.  Piracy is not tolerated here.
AUTODESK 2018 DIRECT DOWNLOAD LINKS
AutoCAD 2018
English 32 bit
English 64 bit – Part 1
English 64 bit – Part 2
AutoCAD LT 2018
English 32 bit
English 64 bit
Inventor Professional 2018 x64
Part 1
Part 2
Part 3
Revit Live 2018
Download
Navisworks Manage 2018
Part 1
Part 2
Navisworks Simulate 2018
Part 1
Part 2
More to come soon...
Autodesk Forums:
Tags (1)
123 REPLIES 123
Message 81 of 124
fqlb
in reply to: TravisNave
Why I have only a few software download,Is it really necessary to legitimate users ?
Message 82 of 124
Matt__W
in reply to: fqlb
A couple of Revit 2018 add-ins were made available last night
Revit 2018 Steel Connections
Revit 2018 Site Designer
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 83 of 124
Hugh_Compton
in reply to: Matt__W
Does anyone know the Product Key for CFD 2018?
Thx
Message 84 of 124
TravisNave
in reply to: Hugh_Compton
@Hugh_Compton
Yes.
Autodesk CFD 2018 809J1
Autodesk CFD Advanced 2018 810J1
Autodesk CFD Design Study Environment 2018 812J1
Autodesk CFD Motion 2018 811J1
I had previously linked all the Autodesk 2018 Product keys (using J this release) in other solutions in this thread.  You can find the entire set here:
https://knowledge.autodesk.com/customer-service/download-install/activate/find-serial-number-product...
Good Luck!
Autodesk Forums:
Message 85 of 124
mdavis22569
Virtual Agent is getting populated
Just was there:
Autodesk AutoCAD 2018
Mike Davis
Message 86 of 124
TravisNave
in reply to: mdavis22569
Thanks @mdavis22569 for letting us know that the Virtual Agent now has many of the 2018 software available.  I have also checked this for Inventor 2018.
With this information, I would now recommend that everyone try downloading their products using the Virtual Agent by following the directions below.
Autodesk 2018 Product Keys
Autodesk Network License Manager 2018
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions...
The rest of the links in this thread should remain active and can be used as well.  We were all very glad to help during this transition!
Good Luck!
Autodesk Forums:
Message 87 of 124
alkassab
Autodesk InfraWorks 360 Pro 2018 (x64)
download link is not working,
Message 88 of 124
TravisNave
in reply to: alkassab
@alkassab,
The other link is working fine.
Thanks!
Autodesk Forums:
Message 89 of 124
Is there a way to get german links from virtual agent?
Message 90 of 124
@tobias_wiesendanger,
Not sure.  Some products are multilingual already.  Which product did you need in German?
Autodesk Forums:
Message 91 of 124
Vault Basic Server and Client and later on all Suites which are not yet released I think?
Message 92 of 124
Yeah, sadly I do not have a link for Vault Basic in German.  And I don't see it in the Virtual Agent either.
Autodesk Forums:
Message 93 of 124
porca_paletta
Installers on VA are english only (excluding softwares with a single multilanguage installer, e.g. Revit)
BTW, here are links for german editions of Vault Basic
Vault Client
Vault Server
I don't know how it works on a Subscription Account, but in my student account I can download all languages available.
BTW there are no 2018 suites are available yet for my account
Message 94 of 124
Thanks for the info and the links.
Message 95 of 124
flashmeBPVJT
Is Inventor 2018 German available?
Message 96 of 124
Sure try this:
Part1
Part2
Part3
Message 97 of 124
thank you
where can i get these direct download links for other products?
Message 98 of 124
@flashmeBPVJT
Welcome to the community..
What product and version are you referring to?
Access the Autodesk Virtual Agent for major Autodesk products and your Autodesk Account for ones that are not on the VA
Mark Lancaster
Message 99 of 124
I found only English Versions in Virtual Agent.
Where's my mistake?
Message 100 of 124
jeffrey.sin
in reply to: flashmeBPVJT
Hi @flashmeBPVJT,
The download links in Virtual Agent are only in English. You can instead download a language pack from the Autodesk Knowledge Network to install on top of your Autodesk software and launch it using the preferred language. For Inventor 2018, you can download the language packs here: http://autode.sk/2p7UDAT.
I hope this helps, let us know how it goes. Thanks.
Jeffrey Sin
Autodesk Customer Support
Administrator Productivity
