Issue: You are having a download failure error, similar to previous releases, that are causing installation errors of your 2018 product. However, the Autodesk Virtual Agent does not yet list the products available for 2018.
Work-Around: Until the Virtual Agent is updated, we collective peers will try to provide Official direct download links from Autodesk. This list may be updated as needed and links may or may not work as products are released. You can also try the Browser Download method from your Autodesk Accounts Management page.
If you have an official direct download link, that is tested and working, or have a URL of a direct download link that should work once the products are released, then please feel free to update the links in the comments below. Please only use official Autodesk links. Piracy is not tolerated here.
AUTODESK 2018 DIRECT DOWNLOAD LINKS
AutoCAD 2018
English 32 bit
English 64 bit – Part 1
English 64 bit – Part 2
AutoCAD LT 2018
English 32 bit
Inventor Professional 2018 x64
Part 1
Part 2
Part 3
Revit Live 2018
Navisworks Manage 2018
Part 1
Part 2
Navisworks Simulate 2018
Part 1
Part 2
More to come soon...
Solved by TravisNave. Go to Solution.
Solved by DarrenP. Go to Solution.
Solved by Darin.Green. Go to Solution.
Why I have only a few software download,Is it really necessary to legitimate users ?
A couple of Revit 2018 add-ins were made available last night
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Yes.
Autodesk CFD 2018 | 809J1 |
Autodesk CFD Advanced 2018 | 810J1 |
Autodesk CFD Design Study Environment 2018 | 812J1 |
Autodesk CFD Motion 2018 | 811J1 |
I had previously linked all the Autodesk 2018 Product keys (using J this release) in other solutions in this thread. You can find the entire set here:
Good Luck!
Virtual Agent is getting populated
Just was there:
Autodesk AutoCAD 2018
Thanks @mdavis22569 for letting us know that the Virtual Agent now has many of the 2018 software available. I have also checked this for Inventor 2018.
With this information, I would now recommend that everyone try downloading their products using the Virtual Agent by following the directions below.
Autodesk Network License Manager 2018
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions...
The rest of the links in this thread should remain active and can be used as well. We were all very glad to help during this transition!
Good Luck!
The other link is working fine.
Thanks!
Not sure. Some products are multilingual already. Which product did you need in German?
Vault Basic Server and Client and later on all Suites which are not yet released I think?
Yeah, sadly I do not have a link for Vault Basic in German. And I don't see it in the Virtual Agent either.
Installers on VA are english only (excluding softwares with a single multilanguage installer, e.g. Revit)
BTW, here are links for german editions of Vault Basic
I don't know how it works on a Subscription Account, but in my student account I can download all languages available.
BTW there are no 2018 suites are available yet for my account
thank you
where can i get these direct download links for other products?
Welcome to the community..
What product and version are you referring to?
Access the Autodesk Virtual Agent for major Autodesk products and your Autodesk Account for ones that are not on the VA
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi @flashmeBPVJT,
The download links in Virtual Agent are only in English. You can instead download a language pack from the Autodesk Knowledge Network to install on top of your Autodesk software and launch it using the preferred language. For Inventor 2018, you can download the language packs here: http://autode.sk/2p7UDAT.
I hope this helps, let us know how it goes. Thanks.
