Issue: You are having a download failure error, similar to previous releases, that are causing installation errors of your 2018 product. However, the Autodesk Virtual Agent does not yet list the products available for 2018.
Work-Around: Until the Virtual Agent is updated, we collective peers will try to provide Official direct download links from Autodesk. This list may be updated as needed and links may or may not work as products are released. You can also try the Browser Download method from your Autodesk Accounts Management page.
If you have an official direct download link, that is tested and working, or have a URL of a direct download link that should work once the products are released, then please feel free to update the links in the comments below. Please only use official Autodesk links. Piracy is not tolerated here.
AUTODESK 2018 DIRECT DOWNLOAD LINKS
AutoCAD 2018
English 32 bit
English 64 bit – Part 1
English 64 bit – Part 2
AutoCAD LT 2018
English 32 bit
Inventor Professional 2018 x64
Part 1
Part 2
Part 3
Revit Live 2018
Navisworks Manage 2018
Part 1
Part 2
Navisworks Simulate 2018
Part 1
Part 2
More to come soon...
Solved by TravisNave. Go to Solution.
Solved by DarrenP. Go to Solution.
Solved by Darin.Green. Go to Solution.
CFD 2018
Part 2 Coming Soon...
This is all I could find for CFD product with a link.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Nastran In CAD 2018
Nastran in CAD 2018 Multilingual 64 Bit
DarrenP
AutoDesk Advance Steel 2018 (x64)
AutoDesk Alias Design 2018 (x64)
Part 1
Part 2
AutoDesk Alias Surface 2018 (x64)
Download
AutoDesk Alias Speedform 2018 (x64)
Download
Autodesk Moldflow Insight Ultimate (x64)
Autodesk Moldflow Adviser Ultimate (x64)
Part 1
Part 2
AutoCAD Plant 3D English 2018 (x64)
Part 1
And as a reminder, while we await the release-dates of more products, the Product Keys for the 2018 line can be found here.
You first indicated there was an error, but we have no clue what the error is..
Next you just stated you can't download Vault Pro 2018 server and client.
You need to give us more specific details instead of a generic description of your problem. What error? Why can't you download?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Products all have different release dates. What is here has been released by Autodesk.
Mark Lancaster
Hi Mark,
Error message when we select download option.
At this point until its resolved.. If you need Vault 2018 stuff you will have to use your Autodesk Account or wait until its resolved.
@TravisNave and @DarrenP All Vault 2018 links are dead including Adv Steel and Nastran In-CAD
Mark Lancaster
Vault Pro 2018
DarrenP
Nastran In CAD 2018
DarrenP
@Mark.Lancaster i reposted them and they are working
no idea what happened the links were working when i posted the first time
DarrenP
Hi all, I'm newbie,
I'm using "Windows 10 x64" : Should I install "AutoCAD x64 or x86" (for personal only) ?
Yes, I know that, but it seems strange to me that Insight is available, but Synergy is not
Here are additional links for Vault:
Autodesk Vault 2018 Basic - Client (x64)
Autodesk Vault 2018 Basic - Server (x64)
Download
I wonder if the e-fulfillment links expire after a certain amount of time? Thanks for the updated links Darren.
