Installation & Licensing
AutoCAD360 - save drawing down
4 REPLIES 4
231 Views, 4 Replies
I would like to save this drawing down to AutoCAD2009.  Can I do that with AutoCAD360 or do I need to use something else?
4 REPLIES 4
DarrenP
no i don't think so
but you can use DWG trueview which is free to use
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
DarrenP
TravisNave
Make sure you save it back to 2007 format, as that is what 2009 uses.
Autodesk Forums:
Hi Lisa,
Those are great answers above and here is a more friendly URL for the Autodesk viewers.
http://www.autodesk.com/viewers
Also the AutoCAD 360 team has there own feedback portal. You may want to go check that out for more AutoCAD 360 related questions.
https://getsatisfaction.com/autocad360
Hope this helps.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
in reply to: Bud_Schroeder_ADESK
Thank you all! I learned something new today. Downloaded TruView and was able to save down the drawings that I needed to. I still love AutoCAD360 though!
Sent from my iPhone
Administrator Productivity
