AutoCAD stops opening
I have problems opening my AutoCAD 2018. I used to have AutoCAD 2015 student version and after it expired I downloaded AutoCAD 2018 - also student version. I was using it just fine, bur after enterning my activation code, AutoCAD 2018 doesn't open. Wihout errors. I also tried opening my Revit 2019 (which I was using a year ago and without any problems) and it has the same problem. Can you please help me? How can I fix it?
natasha.l
Hello @Anonymous,
I understand that you are not receiving an error. In that case please try to launch AutoCAD again, then send the >NFO < files. Let me know what time the event occurred.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
sorry for the delay @natasha.l . It won't attach the file (The file type (.nfo) is not supported) Can I email it to you?
pendean
Community Legend
Community Legend
ZIP the file or change the extension to TXT then post it.
After turning my notebook on, it magically worked. However after some time I tried to run it again and I had the same problem. It was at 18:31 today
