Installation & Licensing
cancelar
Mostrando los resultados de
Quiere decir:
AutoCad not opening in LATITUDE 7490
1 RESPUESTA 1
Responder
Mensaje 1 de 2
1146 Vistas, 1 Respuesta
one of my project lead is facing issue where Autocad(2019) is not working in his Laptop.
We tried different versions and it gives error like below, so the Application opens and gives error.
We also tried to clean his local profile then machine format is also completed but same issue.
I am not sure if his Office Laptop is compatible to work for CAD tools.
He is using Latitude 7490 & I have attached another snapshot for his machine configurations.
Request to kindly have a look and advise.
ALso, pls check Event Viewer log as below.
The program acad.exe version 29.0.46.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 29ec
Start Time: 01d7251ea2258ca0
Termination Time: 4294967295
Application Path: C:\Program Files\Autodesk\AutoCAD 2019\acad.exe
Report Id: 2e42ad08-e91d-41db-bbdb-e8d752bfa098
Faulting package full name:
Faulting package-relative application ID:
Hang type: Top level window is idle"
Etiquetas (1)
Etiquetas (1)
1 RESPUESTA 1
Mensaje 2 de 2
Alfred.NESWADBA
en respuesta a: Anonymous
If there are issues with just one specific dwg-file we would need this file to find out what's in it.
You can run tests by using command _RECOVERALL (instead of _OPEN) to load this file and run checks inside this file and referenced dwg-files if there are any.
Also make sure all updates for AutoCAD are installed, you can start command _ABOUT and show us a screenshot from this dialog so we can tell you if all is up-to-date.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
