Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
AutoCAD LT 2025 for Mac - Register Product - Error (25) for adlmPITSetProductInformation_2: Error has occurred while parsing PIT file
2 RESPUESTAS 2
Responder
Mensaje 1 de 3
laszlo_tarnai
107 Vistas, 2 Respuestas
I install AutoCAD LT 2025 in silent mode via Jamf Pro for our users. We use user-based license.
When the script tries to register the product I get this error:
The command, which was executed is the following:
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk 827Q1 --pv 2025.0.0.F --lt USER --cf /Library/Application\ Support/Autodesk/Adlm/.config/ProductInformation.pit
I tried the following troubleshooting steps:
- did a clean install via Jamf (deleted all related files and folders based on this guide: Clean uninstall of Autodesk programs on a Mac)
- tried to delete and create the PIT file with a script (chmod 644 and chown root:wheel)
- tried to execute the command from Terminal with sudo (just for testing, same result)
- tried to execute with sudo via Jamf
How can I register the product / write the details into the PIT file?
Thank you.
Etiquetas (2)
2 RESPUESTAS 2
Mensaje 2 de 3
Simon_Weel
en respuesta a: laszlo_tarnai
Mensaje 3 de 3
laszlo_tarnai
I try to do exactly the same but I get the mentioned error.
Publicar en los foros
Administrator Productivity
