Hi, I have a problem with AutoCAD LT 2018 . After click 'Activate' it keep pop up request for serial number again, enter a few time it said 'The License manager is not functioning or is improperly installed. AutoCAD LT will shut down now.' I have tried clean uninstall but still the same. Need help, thanks.
I
Solved by ftennyso. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
Hi @shinyee Welcome to Autodesk Community!
Could you please try the solution in this article: AutoCAD: The License manager is not functioning or is improperly installed ? Hope it helps.
Welcome to the Autodesk User's Community..
Your issue is related to this article and you will need to follow the steps that are outline in that article. Thanks for @Darin.Green for troubleshooting this issue a while back and providing the AKN article about it..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Are you having the same issues as the OP was?
If not please create your own posting and explain what your issue is.
Mark Lancaster
Technically you don;t have the same problem as the original poster.. Their issue is related to a renew subscription message that leads to a license manager is not functioning message. You have a separate type of issue that leads to the license manager not functioning and thus requires different steps. That's why I asked...
Perform a license reset by following these steps:
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
First make sure you're signed out of the desktop app and A360 (both are located in your Windows system tray
On your computer, navigate to
2017 Version: C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F [<Product Key> is the product key of the application you have]
2018 Version: C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2018.0.0.F [<Product Key> is the product key of the application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
When you start the application, it will prompt you to choose one (that matches your license) of the following:
Login - 30 day trial or CLIC (Cloud Based) licenses
Serial Number - Students, Standalone and Single-User Term Based activation
Network - Network License server for obtaining licenses from a machine on your network
Good luck and report back on your progress
Mark Lancaster
Thanks for the reply. I think I have same problem as ftennyso too. Now I'm using 30-day trial version but I already subscribe 1-year AutoCAD LT 2018. I have tried clean uninstall several times but it doesn't working. Maybe I have miss some steps ? Or I cannot use the installation file that free download from trial version website?
Thank you.
There is a very important Hotfix that Autodesk recently issued. I must have had my auto install updates turned off in the Autodesk App because I missed it. I, too, used the 30 day trial, leased a 1-year seat, and when through all of license manager issues that everyone listed. I did a clean uninstall and reinstall at least six times and followed followed advice listed on the forum without any success. I worked with one Support Team member who remotely accessed my computer and ran through all of the possible troubleshooting steps that he could think of without success. My case was transferred to a more experience team member who installed the Hotfix, did a clean uninstall, and reinstall and it FINALLY worked. After losing AutoCAD for over a week, I am totally elated!
I think its this..
Mark Lancaster
Hello Mark,
but this seems not to work...i have autocad lt 2018...i have turned on "hiddenfiles" and can't find non of these you have listed....what would be another possibility?
Why are you posting multiple times: https://forums.autodesk.com/t5/installation-licensing/license-error/td-p/7574139 about the same issue? Please post once and someone will help you.
Mark Lancaster
