Installation & Licensing
Autocad freezes when lauching
3 REPLIES 3
aaiisv17
221 Views, 3 Replies
Hello, when launching Autocad2024 it freezes constantly each time, sometimes unfreezes in 7-15 minutes and afterwards works properly, but most of the time it just doesn’t work. I use licensed Autocad 2024, tried to reinstall different versions many times, never helped. tried to reset it, and it didn’t work out. Also installed the NVIDIA graphics but yet didn’t help. Maybe anyone knows the solution.
Tags (1)
3 REPLIES 3
paullimapa
in reply to: aaiisv17
Perhaps try resetting AutoCAD and also don’t migrate any settings from prior versions
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC....
Paul Li
IT Specialist
@The Office
aaiisv17
in reply to: paullimapa
I tried to reset it but it didn't help, maybe some other suggestions?
paullimapa
Next time after AutoCAD finally opens a new drawing at the command line enter
GFXDX12 and set it to 0
Exit AutoCAD and launch it again.
If still freezes for awhile at startup when at command line again this time enter command GraphicsConfig and turn off Hardware Acceleration. Exit AutoCAD again and relaunch to see if that helps. If not a final option is to create a new windows admin account, log off of your current account and logon using that new Windows account and launch AutoCAD from that windows profile.
Paul Li
IT Specialist
@The Office
Administrator Productivity
