Hello everyone,
As you can see in the picture i have a serious problem with autocad 2016 because is not loading up. Just freezes in it. I need it for projects and everything is going bad for me.
Also msvcp100.dll files missing from directory and after installing the .dll files still not working.
Thanks for your time .
Sincerely ,
TONI.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Did you just install this or did something break your operating AutoCAD? How did you know you were missing a DLL?
I guess what I am asking for is a bit of history so I can better understand the issue. What OS are you on? Have you tried repairing C++ and .Net?
Hello @Anonymous,
Not sure what download method you used. If you are using a download now or install now you want to try a more effective method called browser download via the Autodesk Virtual Agent.
Please "Accept As Solution" to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
@Anonymous
The first thing you should do is update the graphics card driver on the machine by downloading it from the vendor's site ( ie. NVIDIA.com ).
With regards to the MSVCP100.dll issue, there seem to be an issue with Visual C++ as @john.vellek stated For that fix, you can review the article here --> Error: "The program can't start because MSVCR110.dll is missing from your computer." when using Autodesk products
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue. Please let us know f you are still encountering an issue and please provide more information. Did this issue occur after installing the product or was the product installed for a while and just started causing an issue.
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Natasha
Helpful Links:
