I am trying to use the helper tooler to activate a standalone licensing on a couple of Macs. I looked at the documentation for the licensing tool and there are no real directions or examples for activation of a standalone license using a serial number. License servers wouldn't work in our environment and these devices get reset enough that having someone manually enter the serial number each time isn't feasible.
I created a command the best I could but I get an error each time I run it.
Error: Error (13) for adlmPITSetProductInformation_2: PRODUCTS information is not found
The command I am running is:
/Library/Application\ Support/Autodesk/AdskLicensing/12.2.0.17/helper/AdskLicensingInstHelper register --prod_key 77701 --prod_ver 2023.0.0.F --config_file /Library/Application\ Support/Autodesk/Adlm/.config/ProductInformation.pit --lic_method STANDALONE --serial_number Serial#
I believe that should work. The part I am most unsure about is the config_file section. That is the file I found on the device but I am sure why they are even asking is they are the one that placed the file there or are they referring to some other file? Like I said, no example or directions for this method.
I know that product info is correct since when I run this list command I get the following.
"feature_id": "ACDMAC",
"def_prod_key": "777O1",
"def_prod_ver": "2023.0.0.F",
"sel_prod_key": "777O1",
"sel_prod_ver": "2023.0.0.F",
"user_lic_enabled": true,
"cls_check_succ": true,
"supported_lic_methods": [
2,
1,
4
"serial_number_sa": "xxx-xxxxxxxx",
"serial_number_nw": "xxx-xxxxxxxx",
"icon": "/uiassets/dda7cce1e4766c9727728385c46fe17f.png",
"background": "/uiassets/eaa59d2b7e16968c345dda102a9a429f.png",
"highlight": {
"red": {
"value": 255
"green": {
"value": 55
"blue": {},
"alpha": {}
"def_prod_code": "ACDMAC",
"sel_prod_code": "ACDMAC"
I have tried other variations of the command but I always get that error. Any help that someone would give would be great.
