Hello everybody,
My Autocad is shutting down
error message:
acminidump.dmp
dmpuserinfo.xml
dumpdata.zip
I am using Autocad design suite ultimate 2013.
thank you.
Can you provide any system specs and info?
2013 has been out of support for a while...
Hello @Anonymous,
Do you meet the system requirements? Are you opening a AutoCAD file? Or just opening AutoCAD by itself?
AutoCAD, the program crashes with a fatal error
Object/File
If the issue is only related to the file you are opening with AutoCAD. It maybe associated to an object you can try the steps here to isolate the item in the drawing using QSELECT. Along with some other troubleshooting steps.
Display
If the issue is not associated with a file, it could be display related & the performance issues could be related to the graphic card or AutoCAD drawing file has complex components.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
hi @Anonymous
Can you share the dumpdata.zip from the %temp% folder
Also, what OS are you on?
If it's on Windows 10... know that this OS isn't supported for anything 2015 and older:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Windows-10-support-for-Autodesk-products.html
All 2017, 2018, 2019, and 2020 Autodesk software runs on Windows 10. You can also run many 2016 products on Windows 10 with the application of the Autodesk service pack specified in the system requirements. Most 2015 and earlier products are not compatible with Windows 10, unless otherwise stated in the system requirements.
