Installation & Licensing
cancelar
Mostrando los resultados deĀ
MostrarĀ Ā soloĀ  | Buscar en lugar deĀ
Quiere decir:Ā
AutoCAD crashes after a computer crash
5 RESPUESTAS 5
Responder
Mensaje 1 de 6
c76zhang
431 Vistas, 5 Respuestas
I have had problems opening my AutoCAD after a computer crash today. The software can be launched, but will shut itself down after ~4mins and throwing a fatal error. The report number given by the error message is 713615485. Any advice on how to proceed is appreciated.
Best,
Chi
Etiquetas (3)
Etiquetas (2)
5 RESPUESTAS 5
Mensaje 2 de 6
paullimapa
en respuesta a: c76zhang
Did you try doing a complete shutdown before turning your computer back on & trying to run AutoCAD then?
Paul Li
IT Specialist
@The Office
Mensaje 3 de 6
Valentin-WSP
@c76zhang ,
In addition, consider doing a Repair.
Also, try the suggestion from these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Mensaje 4 de 6
Simon_Weel
Could be a corrupted user profile, as described in the articles mentioned in the links. I notice there's no solution given on how to remedy that. Depending on the version you have, delete a registry key and a folder. Run these command's from CMD:
reg delete "hkcu\Software\Autodesk\AutoCAD\R24.3" /f
rd /s /q "%appdata%\Autodesk\AutoCAD 2024"
In this case, the registry key and folder for AutoCAD 2024 will be removed. After that, restart AutoCAD and your user profile will be recreated.
Mensaje 5 de 6
TravisNave
Have you tried a Windows System Restore Point from before the crash, by chance?
Autodesk Forums:
Mensaje 6 de 6
mdavis22569
@c76zhang
Can you share your DUMPDATA.ZIP from the %temp% folder .. there should be a zip file.
Mike Davis
ĀæNo encontraste lo que buscabas? PregĆŗntale a la comunidad o comparte tus conocimientos.
Publicar en los foros
Administrator Productivity
