AutoCAD 2023 - Windows11 startup issue
costantinomastroianni1
Message 1 of 11
Buongiorno. Autocad 2023 si avvia in windows 11 nella "modalità efficienza". Questo in certe situazioni porta ad un blocco del software che induce a forzare l'arresto e al riavvio. E' possibile disattivare la modalità efficienza? Ho provato dal task manager di windows 11 ma non consente la disattivazione.
GOOGLE TRANSLATE:
Good morning. Autocad 2023 starts in windows 11 in "efficiency mode". This in certain situations leads to a software block which induces a forced shutdown and restart. Is it possible to deactivate the efficiency mode? I tried from the windows 11 task manager but it doesn't allow deactivation.
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Have you installed the 2023.1.1 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
HTH
Message 3 of 11
mdavis22569
@costantinomastroianni1
What is your Build of Windows 11?
Mike Davis
Message 4 of 11
22H2 (build SO 22621.900)
Message 5 of 11
mdavis22569
Can you share what you have for the CPU, amount of RAM / GPU ?
Mike Davis
Message 6 of 11
Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz
RAM 16Gb
NVIDIA GeForce GTX 1660 Ti
Message 7 of 11
a_cont
Observer
Observer
Io ho lo stesso problema qualcuno sa dirmi come risolvere? Ho tutto aggiornato, ho autocad Lt 2023.1.2 I7 3,50 GHz con ram 32GB e scheda NVIDIA RTX A2000
Added English translation for clarity:
I have the same problem can anyone tell me how to fix it? I have everything updated, I have autocad Lt 2023.1.2 I7 3.50 GHz with 32GB ram and NVIDIA RTX A2000 card ( Mike )
Message 8 of 11
mdavis22569
https://timesofindia.indiatimes.com/gadgets-news/explained-windows-11-task-manager-efficiency-mode-w....
Mike Davis
Message 9 of 11
mdavis22569
Just doing a quick follow-up to see if you're all set.  Or if you need help still
M
Mike Davis
Message 10 of 11
a_cont
Observer
Observer
No non sono riuscito e autocad utilizza sempre troppa memoria.. se qualcuno può dare delle spiegazioni.. mi sembra strano che un pc nuovo con queste caratteriastiche non riesce a far girare bene Autocad.
Processore: 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
RAM installata: 32,0 GB (31,6 GB utilizzabile)
Tipo sistema: Sistema operativo a 64 bit, processore basato su x64
Edizione: Windows 11 Pro
Versione: 22H2
Fateci sapere al più presto grazie
Edited to add English Translation --------------------
No, I didn't succeed and Autocad always uses too much memory.. if someone can explain it.. it seems strange to me that a new pc with these characteristics cannot run Autocad well.
Processor: 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50GHz
RAM installed: 32.0GB (31.6GB usable)
System Type: 64-bit operating system, x64-based processor
Edition: Windows 11 Pro
Version: 22H2
Please let us know as soon as possible thanks
Message 11 of 11
mdavis22569
What is your video card and driver?
All of the updates installed?
Mike Davis
