Hello everybody,
today I try to install and run new AutoCAD 2023 app. When i try run the installed app i have error wchich is schowed in attached screenschoot. On the same device I have AutoCAD 2022 app and it works fine. I have already installed AC2023 on two other devices and they work fine.
I try to reinstall this many times and install with different instalation and download options. I also tried instruction form this topic: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-...
but the error still exist.
I hope you can help me.
¡Resuelto! Ir a solución.
Resuelto por ntenthorey5U7LH. Ir a solución.
Resuelto por mdavis22569. Ir a solución.
Hello @d.nykiel,
Thanks for sharing the steps you have taken thus far.
When you attempted to reinstall did you try a different download method?
Try conducting the steps below to resolve this issue:
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
@jesseguevara wrote:
no luck. I did a clean Uninstall. I also downgraded to 2022 autodesk Lt.
I received this error attached.
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
yea i got a reply from a support ticket finally and she instructed me to do a clean uninstall and redownload autocad using the autodesk app only not the browser. it did not work. video of the error
Try reinstalling the C++ / .NET
Try the C++ /.NET reinstall I shared a couple of messages up.
Great! I repaired .Net in control panel, used the Microsoft Uninstaller Tool to Uninstall. Rebooted, reinstalled, and its working now.
unfortunately in my case none of the above advice solved the problem. I have tried everything:
- repeated clean installation of AutoCAD 2023 from different sources and different language versions (interestingly in the Autodesk desktop application, I never get the option to install AutoCAD 2023. I can install all other programs like Revit, Robot etc. without any problem from the Autodesk desktop application. If I install Advance Steel 2023 from within this application it also installs AutoCAD 2023 but always with the same errors as from other sources),
- repeated reinstallation of C++ /.NET packages.
During today's attempt there were new errors when starting the freshly installed AutoCAD 2023, I add them in the appendix,
- installing AutoCAD 2023.1 update by downloading the installer from the Autodesk website.
During today's attempt, new errors have appeared when launching the freshly installed AutoCAD 2023. I add 3 in the attachments. The fourth one is "AcGe24.dll".
Does anyone know how to fix this?
Did you try to uninstall and after that install ALL MS Visual C++ Redistributables you have on your machine. I downloaded them through the Microsoft website.
It worked for me when I had an issue with Civil 3D 2022 installation after uninstalling Civil 3D 2021.
BTW try to avoid British/International English versions and install the English version.
Good luck ![]()
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
