Installation & Licensing
cancelar
Mostrando los resultados de
Mostrar  solo  | Buscar en lugar de
Quiere decir:
AutoCad 2022 Installation Failed
31 RESPUESTAS 31
Responder
Mensaje 1 de 32
tjsduddl97
6247 Vistas, 31 Respuestas
I was downloading AutoCad 2022 and for some reason, I couldn't download it.  It didn't tell me what is the problem, just kept saying try again. I tried more than 5 times and still can't figure it out. My windows is the latest version and also downloaded Direct X but still not working. Can you please help me?캡처gg.JPG
Etiquetas (2)
Etiquetas (1)
31 RESPUESTAS 31
Mensaje 2 de 32
ennujozlagam
en respuesta a: tjsduddl97
have you try to switch off all your anti virus program and firewall and try again and see if helps. thanks
Mensaje 3 de 32
tjsduddl97
en respuesta a: ennujozlagam
I only have windows virus program so I don't think that's why. It is so frustarating.
Mensaje 4 de 32
ennujozlagam
try to refer here and see if helps. thanks
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
Mensaje 5 de 32
leowarren34
Hi @tjsduddl97,
Is this the Browser Download Method?
If not try it since it tends to be less sensitive to network conditions;
Direct Links below:
https://efulfillment.autodesk.com/NetSWDLD/2022/ACD/1E7D4EF7-A28E-3D3E-BA3C-C6FAE4AAB2E0/SFX/AutoCAD...
Have you also run the installers as admin?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mensaje 6 de 32
tjsduddl97
Thanks so much. I'll try it!
Mensaje 7 de 32
tjsduddl97
en respuesta a: leowarren34
I tried the link that you gave and it still didn't work :(( Thanks tho. It was faster than before another link but couldn't install it.. I really don't know how to fix it
Mensaje 8 de 32
mdavis22569
@tjsduddl97
Clean out your %temp% folder ...
Make sure that the Anti-Virus an Firewall are off.
Make sure you have Admin rights on the machine
How much space is on your C:\ (available space)
Mike Davis
Mensaje 9 de 32
tjsduddl97
en respuesta a: mdavis22569
I can use 634GB and I don't think that's enough for AutoCAD for sure. I got this new PC like two months ago so I don't think pc is the problem. I really hope to bring my pc to someone who knows AutoCAD very well and figure out why it's not working..
Mensaje 10 de 32
mdavis22569
What is the build of your W10?
UAC set to the lowest and you have Admin rights?
Mike Davis
Mensaje 11 de 32
srinivasarao.potla
hi @tjsduddl97
Thanks for your feedback.
I would like to know more about the issue. could you please send me the log files from the following location? location C:\Users\username\AppData\Local\Autodesk\ODIS
Srinivas.
Mensaje 12 de 32
tjsduddl97
W10 Education 64-bit (10.0, Build 19042)
UAC set to lowest
cleared the temp folder
ran as admin
Log below:
Permissions Error Summary
The following permissions errors were encountered. Please review the details below in this file
---One or more registry keys could not be opened for write
---One or more directories are read-only
Machine Settings & Runtime Versions
Platform Information
Operating System = Windows-10-10.0.19041 64 bit
Processor = AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
Folder Shell Redirections - Per User
AppData = C:\Users\유갱\AppData\Roaming
Local AppData = C:\Users\유갱\AppData\Local
CD Burning = C:\Users\유갱\AppData\Local\Microsoft\Windows\Burn\Burn
{1B3EA5DC-B587-4786-B4EF-BD1DC332AEAE} = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Libraries
My Video = C:\Users\유갱\Videos
My Pictures = C:\Users\유갱\Pictures
Desktop = C:\Users\유갱\Desktop
History = C:\Users\유갱\AppData\Local\Microsoft\Windows\History
NetHood = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Network Shortcuts
{56784854-C6CB-462B-8169-88E350ACB882} = C:\Users\유갱\Contacts
{00BCFC5A-ED94-4E48-96A1-3F6217F21990} = C:\Users\유갱\AppData\Local\Microsoft\Windows\RoamingTiles
Cookies = C:\Users\유갱\AppData\Local\Microsoft\Windows\INetCookies
Favorites = C:\Users\유갱\Favorites
SendTo = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\SendTo
Start Menu = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Start Menu
My Music = C:\Users\유갱\Music
Programs = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Recent = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Recent
PrintHood = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
{7D1D3A04-DEBB-4115-95CF-2F29DA2920DA} = C:\Users\유갱\Searches
{374DE290-123F-4565-9164-39C4925E467B} = C:\Users\유갱\Downloads
{A520A1A4-1780-4FF6-BD18-167343C5AF16} = C:\Users\유갱\AppData\LocalLow
Startup = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Administrative Tools = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Personal = C:\Users\유갱\Documents
{BFB9D5E0-C6A9-404C-B2B2-AE6DB6AF4968} = C:\Users\유갱\Links
Cache = C:\Users\유갱\AppData\Local\Microsoft\Windows\INetCache
Templates = C:\Users\유갱\AppData\Roaming\Microsoft\Windows\Templates
{4C5C32FF-BB9D-43B0-B5B4-2D72E54EAAA4} = C:\Users\유갱\Saved Games
Fonts = C:\Windows\Fonts
Folder Shell Redirections - Per Machine - 32 Bit
Common Administrative Tools = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Common AppData = C:\ProgramData
Common Desktop = C:\Users\Public\Desktop
Common Documents = C:\Users\Public\Documents
Common Programs = C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Common Start Menu = C:\ProgramData\Microsoft\Windows\Start Menu
Common Startup = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Common Templates = C:\ProgramData\Microsoft\Windows\Templates
CommonMusic = C:\Users\Public\Music
CommonPictures = C:\Users\Public\Pictures
CommonVideo = C:\Users\Public\Videos
OEM Links = C:\ProgramData\OEM\Links
Folder Shell Redirections - Per Machine - 64 Bit
.NET Versions installed
4.8.04084 (no service pack) (32 bit)
4.8.04084 (no service pack) (64 bit)
Visual C++ Runtimes installed
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 = 10.0.40219
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 = 10.0.40219
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 = 11.0.61030.0
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 = 11.0.61030.0
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 = 11.0.61030
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 = 12.0.30501.0
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40664 = 12.0.40664.0
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 = 12.0.30501.0
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40664 = 12.0.40664.0
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.40664 = 12.0.40664
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.40664 = 12.0.40664
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.40664 = 12.0.40664
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.40664 = 12.0.40664
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29334 = 14.28.29334.0
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29334 = 14.28.29334.0
Microsoft Visual C++ 2019 X64 Additional Runtime - 14.28.29334 = 14.28.29334
Microsoft Visual C++ 2019 X64 Minimum Runtime - 14.28.29334 = 14.28.29334
Microsoft Visual C++ 2019 X86 Additional Runtime - 14.28.29334 = 14.28.29334
Microsoft Visual C++ 2019 X86 Minimum Runtime - 14.28.29334 = 14.28.29334
Autodesk Components installed
Autodesk AutoCAD Performance Feedback Tool 1.3.8 = 1.3.8.0 UninstallString = MsiExec.exe /X{3EDD9D7F-E305-485B-A0E5-7F6D24A87093}
Autodesk Genuine Service = 3.2.18 UninstallString = MsiExec.exe /X{54A00624-3EF9-49A2-92A9-7244EADD0212}
Autodesk Installation Diagnostic Assistant = 1.5.0.0 UninstallString = MsiExec.exe /I{0C4B4EEC-C4E5-4E3E-B502-9BEAECBC3F01}
Autodesk Material Library 2022 = 20.3.7.0 UninstallString = MsiExec.exe /X{A9221A68-5AD0-4215-B54F-CB5DBA4FB27C}
Autodesk Material Library Base Resolution Image Library 2022 = 20.3.7.0 UninstallString = MsiExec.exe /X{6256584F-B04B-41D4-8A59-44E70940C473}
Autodesk Single Sign On Component = 12.3.3.1803 UninstallString = MsiExec.exe /X{B9F5BDED-021C-4926-8518-4FA7114B7040}
Link to running processes on computer
AutodeskPermissionsTest_processes.txt
Free Disk Space:
Drive C = 671294836736 bytes free
Link to mapped & substituted drives on computer
AutodeskPermissionsTest_mappings.txt
Permissions Tests:
Directory Access: ProgramFiles
---Path: C:\Program Files
---Exists = True
---Read = True
---Write = False
---Applies To = all
Directory Access: ProgramFiles(x86)
---Path: C:\Program Files (x86)
---Exists = True
---Read = True
---Write = False
---Applies To = x64
Directory Access: ProgramData
---Path: C:\ProgramData
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: AppData
---Path: C:\Users\유갱\AppData\Roaming
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: LocalAppData
---Path: C:\Users\유갱\AppData\Local
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: CommonFiles
---Path: C:\Program Files\Common Files
---Exists = True
---Read = True
---Write = False
---Applies To = all
Directory Access: CommonFiles(x86)
---Path: C:\Program Files (x86)\Common Files
---Exists = True
---Read = True
---Write = False
---Applies To = x64
Directory Access: Temp
---Path: C:\Users\유갱\AppData\Local\Temp
---Exists = True
---Read = True
---Write = True
---Applies To = all
Directory Access: TMP
---Exists = True
---Read = True
---Write = True
---Applies To = all
Registry Access: HKLM_Software
---Key: HKEY_LOCAL_MACHINE\Software
---Read = True
---Write = False
---Applies To: all
Registry Access: HKCU_Software
---Key: HKEY_CURRENT_USER\Software
---Read = True
---Write = True
---Applies To: all
Mensaje 13 de 32
tjsduddl97
en respuesta a: srinivasarao.potla
I don't know which one is so I just took a screenshot of the folder.
Mensaje 14 de 32
srinivasarao.potla
Hi @tjsduddl97
please zip all the files in that folder send me.
Srinivas.
Mensaje 15 de 32
tjsduddl97
Here it is.
Mensaje 16 de 32
er.dejong
Any news on this problem?
I have a user with the same problem. There it gave this line in the Install.log:
2021-04-06T12:55:15.686 [Install Manager: 21380, single] [InstallManager WARN] [ Autodesk::DDA::IMUtils::GetBundleInfoListFromJson ] Input Json is empty!
Does this mean something is wrong with Java?
Mensaje 17 de 32
srinivasarao.potla
Hi @tjsduddl97
thanks for sharing the log files.
The installation failed due to licensing component.
2021-04-04T20:23:03.303 [Install Manager: 12624, single] [InstallManager INFO] [ InstallManager::HandleInstallFailure ] Failed to install Package (upi2: {D93E01D9-AF6E-32E9-ACA2-61D9E92563C1} name: Autodesk Licensing Installer 1.0 ) Error Code: 240 Exit Status: 2
Please uninstall the licensing component and try to to -re install the product.
Hope this helps.
Srinivas.
Mensaje 18 de 32
tjsduddl97
Oh I see. How can I delete the licensing component?
Mensaje 19 de 32
srinivasarao.potla
Hi @tjsduddl97
open the control panel and delete it.
the following link may help
https://forums.autodesk.com/t5/installation-licensing/download-failed-installation-aborted-result-16...
Srinivas.
Mensaje 20 de 32
after series of testing, in the past for previous versions 2021 and below, Autodesk is instructing us to clean up everything, clean slate, it is not applicable to 2022 version tho. From the custom install for enterprise now available on the account's portal, they changed how we generate install for enterprise deployment and this is where I found most of the logs aside from the ODIS log. From the customization products I've chosen, here's the log. Cleaning up this directory if there's already an existing 2022 install, will surely fail on the reinstall.
C:\Program Files\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files (x86)\Common Files\Autodesk Shared
C:\ProgramData\Autodesk
HKLM\Software\Autodesk
HKLM\Software\WOW6432Node\Autodesk
I already escalated and submitted my ODIS to the chat support for escalation and I'm still figuring out what are the specific entries defined which Installer.exe/ODIS/xml are looking for during install
After 15hrs testing and reinstall/reimaging, that's what i found out so far. Leaving those entries will make the install smoothly but deleting any of those, you'll have to reimage instead.
Publicar en los foros
Administrator Productivity
