I have recently start a project which will require me to work in an area where for the majority of 6 months i will have no internet connection. I need to use my current AutoCAD 2019 software while in this area. my 2 questions are:
1) what bandwidth do i require to confirm licence activation
2) is there a method of having a perpetual licence or the codes in advice?
Thank you.
Solved by Mark.Lancaster. Go to Solution.
All Autodesk Subscriptions need their activation status verified every month,
Bandwidth is less of a concern but obviously the higher the bandwidth the faster it will sync up.
As for getting future verification codes - unlikely if not impossible.
@Anonymous
Welcome to the Autodesk User's Community..
First is your AutoCAD 2019 license a carried over perpetual license or a subscription based.
If former, no internet connection required
If latter, as long as you have a internet connection in the background, even a low end the product just checks and moves on. However each day if it can't find that internet connection it goes into a 30 day off-line counter and when it reaches 0 days left the product will no longer work. So I assume you are staying someone at night that has internet connection so, once you reconnect there the counter is reset.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Anytime, happy to help 🙂
