AutoCAD 2018 activation failure if documents folder is redirected to network
When I activate AutoCAD 2018 on a Windows 10 Pro (build 1703) machine with a single user license the activation window displays 2 script failures and stops responding.
On this machine the documents folder is redirected to a network location a Windows 2012 server via group policy. When I disable this redirection and set the documents folder to the local disk that activation succeeds.
After activation I've reactivated documents folder redirection and AutoCAD still starts up properly.
I guess this is a bug in the activation software?
Otto
Hello znrbv and welcome to the Autodesk community!
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking these pages and checking back often; we'll update with new information as our testing continues.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
If you are redirecting the user profile information Autodesk does not support this.
Mark Lancaster
I'm not redirecting the complete user profile (roaming profile) but only the documents folder.
So your saying AutoCAD 2018 does not support network paths? This just seems to me like a bug in the license activation code.
I would have expected this answer about 20 years ago but not in 2017 for a product that costs almost € 1800,- a year! Shame on you Autodesk. Please fix this!
abblomquist
Yes, please fix this. We also redirect all of our user's documents folder to a network folder.
squeakstar
Autodesk should support redirected folders it's a common thing in business environments to keep users documents backed up to a server.
THIS used to work up until 2018 versions, the latest version of the Autodesk app running in the background is a complete joke when the 2017 version worked fine with redirected folders, given some minor tweaks to make your server's redirected folder destination a trusted source.
This worked for us prior to 2018.. Internet Explorer > Internet Options > Security > Local Intranet > Sites > Advanced
Add your file server to the Intranet sites zone like this...
file://servername
if you use DFS shares add this too..
file://*.domain.suffix (eg *.domain.com)
So Autodesk.. are you asking us to completely redesign our computer/servers/network around your products you can't be arsed to program around, yet continue to force us down lucrative subscription contracts AND remove existing features that worked happily previously?
Take a long hard look at yourself and ask yourself are you working for the benefit of customers or just your own money grabbing existence?
simon_thwaites
Observer
Observer
This really needs to be sorted.
Enterprise software for enterprises... we need enterprise features. We're paying enterprise prices.
This happens in other Autodesk software too (Trueview recently had this problem).
FYI redirection does work if you don't have a . in the username. Obviously the solution on the knowledge base is to remove the dot, not helpful.
Why does this even need to rely on a location in the documents folder - im sure it wants to save there at some point but come on...
